Everyone Please Help!!!!!!
Old Apr 21, 2003 | 04:35 PM
stik6shift98's Avatar
Unhappy Everyone Please Help!!!!!!
so in response to my low oil pressure i have concluded what i think the problem is
please give me your opinions and PLEASE tell me that IM WRONG
my symptoms:
low oil pressure
knocking
ticking
bottom end gone
and i think it mikght help to add that i just put it a head and cam package on it about 3 days ago.....
so what do u think???
Old Apr 21, 2003 | 04:55 PM
jd13's Avatar
I'm not too knowledgable about digging into engines that way, but I don't think it's your bottom end.
I think that something just wasn't put back in place right, or something like that. I'd say open it up and take a look around. For your sake, I hope thats it.
Old Apr 21, 2003 | 04:57 PM
Ferocity02's Avatar
Time for a stroker kit
Old Apr 21, 2003 | 09:20 PM
2002Z28SSConv's Avatar
Okay, now you've got an aftermarket oil pump, head/cam combo and what else?
Go ahead and tell us everything you've done to the engine in the past month please.
Old Apr 21, 2003 | 11:45 PM
past month
heads/cam
ls6 intake
oil pump
slp double roller timing chain
cometic head gaskets
thats about it for the last month
my poor car
Old Apr 22, 2003 | 01:51 AM
Is it knocking as in ping knock or bearing knock? Ping knock could be due to incompatible ECM programming now that you have the head/cam combo in. Did you have it tuned?
If I was going to bet a dollor though, I would still expect a problem with the cam bearings, lifters, rocker arms or the valve springs especially. That was the last change.
I'd pull the valve covers off and inspect the valve springs, rockers and push rods. You might have had bearing failure on the cam and now you're getting some play in there. That would also cause a loss of oil pressure. Or you had a spring failure and now the valve train is knocking itself around. If your cam has a lot of lift you might also be getting piston to valve clearance issues causing bent valves and pushrods, misfiring due to loss of compression and noisy valve train.
But if the oil pressure is a lot lower now than it was when everything was just installed, you probably have cam bearing issues. I doubt that you would have bottom end problems due to oil starvation unless the pressure was VERY low. And it doesn't sound like that is the case. Either way though, it sounds like the engine is due for disassembly.
Old Apr 22, 2003 | 01:58 AM
it has .581 lift
and heads where made to specs of it too
hey 2002 z if u have aim please aim me stik6shift98
thanks
Old Apr 22, 2003 | 02:47 AM
Originally posted by stik6shift98
it has .581 lift
thanks
I finally got my Aim working. But it says you're offline.
Old Apr 22, 2003 | 09:10 PM
try again
Old Apr 22, 2003 | 10:22 PM
96Z28/93TA's Avatar
stickshift ... how many miles have you put on the car since speed inc. installed the mods?? if your knock happened right away, there is a very good chance they installed something wrong...on the other hand if you have been beating the **** out of the car since you got it back from them and put on some miles, then the bottom end probably just couldnt hold all the extra hp from the new mods. sorry to hear it
Old Apr 22, 2003 | 10:45 PM
60 miles
my car has 28k miles all together
im getting a new engine for now nad ill build this one up
and yone know where to get some writeups and how tos on pulling and engine and doing a stroker?
Old Apr 22, 2003 | 11:00 PM
96Z28/93TA's Avatar
Something sounds fishy to me, unless you was using your NOS, I think your install wasnt done "professionally". Im not blaming them but there is a lot of things they could have done wrong. It is easy to ruin cam bearing when installing a camshaft if its not done right or having debris run though your engine blocking an oil passage and starving that main bearing of oil ect... Unless you did something to really hurt the car in 60 miles then something is not right. before you cam/head install you had 100 shot of nitrous, this is going to be harder on you engine then the 75 hp the cam and heads gave you (estimated). I would really raise a fuss at speed inc.... but in there defense, if you went out a tested your car with the new cam/heads and using your nitrous- then it probably just exceeded the limits on your stock bottom end in any case good luck!
Old Apr 22, 2003 | 11:02 PM
dj haf's Avatar
dammmn dude, what a bad one
Old Apr 22, 2003 | 11:04 PM
Ferocity02's Avatar
Good luck with the new engine. I think you were just a victim of a faulty engine. Couldn't handle the power from the heads and cam.
Here is some info:
Stroker Kits (not LS1, Jeep, basically the same idea, good info)
Motor Pulling (might help)
Pulling an LS1 will be a little bit harder because the engine is under the dash. All you really need to do is remove the radiator, fans, all that so you have enough room to move the engine forward. Remove all wires to the engine. Remove anything to make the engine easier to get out, and the new one in. Unbolt from mount, y-pipe, and tranny and you should be good to go. Definitely need an engine crane thing.
Good luck man!
Old Apr 22, 2003 | 11:12 PM
i thought the same thing....i didnt spray it....i dont even have a bottle in the car and anyway speed inc messed up the wiring for nitrous cuz my switches dont work
