Engines
Old Oct 27, 2003 | 09:38 PM
TM98's Avatar
Engines
What are the differences between an LS1, LS6, LT1, LT4, and TPI. I'm pretty sure that they are all 5.7L, but I can't figure out what makes them different from each other, other than intake manifolds. What kind of performance differences does each one have?
I know its kind of a big question, but everyone I've asked has never given me a straight answer.
Thanks for any help in clearing up the differences.
Old Oct 27, 2003 | 11:06 PM
mr_muff's Avatar
block design, head design, intake manifold. pretty much everything. the lt1's i think are actually a 349ci (don't quote me in that) and the ls1's are a 346ci. there are a lot of differences
Old Oct 27, 2003 | 11:15 PM
Steve0's Avatar
TPI motor is your basic small block fitted with fuel injection. This was used in the 80s.
Then in 92 the LT1 was released. Its basially a TPI motor with a better intake manifold and igntion system. The LT4 is just a LT1 with better heads, cam and a 4 bolt block.
The LS1 is a totally different design. It shares nothing with the older generation small blocks. It has good flowing heads, even better igntion, and a broader powerband. It also has an aluminum block. The LS6 is what the LT4 was to the LT1. It is essentially a LS1 with better heads and cam.
Old Oct 28, 2003 | 12:32 AM
tailwindxr7's Avatar
The LS1 is also a six-bolt main.
The F-body LT1 was a 2-bolt main, the Corvette LT1 and the LT4 were 4-bolts.
willismoons
Feb 14, 2015 08:42 PM
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
centric
Aug 15, 2002 09:04 PM
Caps94ZODG
22
Jul 30, 2002 08:45 AM
