Engine knock when cold
Old Jul 5, 2007 | 08:29 PM
rel3rd's Avatar
Question Engine knock when cold
I just picked up this 2000 SS Camaro a week and a half ago.
When engine is cold, it has a noticeable "knock" that sounds like a rod knock. It is definitely NOT a valve tap...it sounds much deeper.
When engine is warmed up, the noise is all but non-existent.
Oil pressure reads 60psi at light throttle cruise
Just shy of 40psi at warm idle
50psi at cold idle.
Original owner said he used Mobil1 only.
Engine has 110,000 miles but runs fantastic.
If you rev the engine up, noise is gone...or at least I cannot hear it then.
I tried SEARCH function here and elsewhere and most engine knocks seem to be when HOT, not when COLD....
Any ideas?
Old Jul 5, 2007 | 09:39 PM
95LT1conv's Avatar
sounds like piston slap. "normal" in a ls1 I believe.
Old Jul 6, 2007 | 07:13 AM
AL SS590 M6's Avatar
Moderator
Yes it's quite normal in an LS engine. They have a very short skirted aluminum piston that can rattle when cold but it expands as it warms up and the noise goes away, usually within a minute or so.
Old Jul 6, 2007 | 10:52 AM
Marc 85Z28's Avatar
Again, normal for LS1s according to GM. Some do it, some don't. Do a search on "piston slap" for TONS more info. And while you're searching, there is a lot of information on engine oils, and why Mobil 1 products (especially as of late) are not optimum for the LS1. Some people have had success quieting the noise with a different oil.
Old Jul 6, 2007 | 02:35 PM
Kraest's Avatar
Retired
Welcome to the LS1. Please try the fish
Old Jul 6, 2007 | 02:44 PM
Stevo's Avatar
What oil do you use for your LS1?
Old Jul 6, 2007 | 08:22 PM
rel3rd's Avatar
I'm also wondering what is, or may be, better for this car...
Most of what I could find last night said Mobil 1
Old Jul 6, 2007 | 08:24 PM
rel3rd's Avatar
BTW, thanks for the replies guys...I can live with a "normal noise" that all but goes away...
Old Jul 7, 2007 | 10:11 AM
Marc 85Z28's Avatar
I use synthetic oil in all of my vehicles. And since Mobil 1 no longer makes a true synthetic oil, I use Castrol Syntec and Amsoil.
Old Jul 9, 2007 | 07:47 PM
hurraquio's Avatar
I used Penzoil 10/30 this oil change and its ok. next oilchange im thinking Advance Q or Royal Purple
Old Jul 11, 2007 | 02:58 PM
Bobsep84's Avatar
I have an LT1 and use Mobil 1 0w-40....from what i read this a great oil for the LSx and LTx
Old Jul 12, 2007 | 05:05 AM
Moderator
Except for the fact that in the manual in a warning bubble it says not to run any oil thicker than 30w.
Old Jul 15, 2007 | 10:37 AM
camaroz2866's Avatar
its a perforamnce motor, thicker oil will not hurt it any, im in the road racing scene and we have 2.3L 4cylinders using 15/50 full syn for a couple of seasons they last thats a few years of every weekend running the **** out of these at almost 8grand
Old Jul 15, 2007 | 12:33 PM
Kraest's Avatar
Retired
That's true.........
..........If you're running a 2.3L 4-banger
Old Jul 15, 2007 | 06:42 PM
Moderator
It's got nothing to do with whether it's a performance motor or not. It's all about oil clearances in the bearings. LSx factory oil clearances are designed for 30 weight oil and running thicker oil reduces the amount of oil per minute the flows thru that gap causing excess heat at the bearing surfaces.
And who gives 2 cants for how you abuse a 4 banger?
jayblev95
Dec 1, 2014 06:55 AM
thenewkid
Nov 27, 2014 09:41 AM
Lions3
Apr 11, 2003 10:55 AM
NJ SPEEDER
Jul 19, 2002 10:22 PM
