Engine Cuts at 120
Old Aug 7, 2004 | 10:27 AM
  #16
stone4779's Avatar
Re: Engine Cuts at 120
Originally Posted by StylezZ28
umm w/o a speed limiter i would thing an M6 would go much faster then 159... i got to 155 and still had some more of 5th and 6th to go..
yeah even with my 4.11's I still barely peg the speedo in 5th.(5th gear runs out right at 155) I havnt tried to see what 6th feels like on the top end with my gears...I need to get better tires first...
I imagine I can still have pull on the top end in 6th, since I have 4.11's
I am making a road trip to Rio Grande Valley on the 20th, and my favorite top speed test-road is on the way. Theres room to top out and more....nothing but open stretch.
I'll let you guys know. I wish I had a separate speedometer to know how fast Im going...but at least I can take along my little printout showing RPMvsMPH and know once I finish.
Hope fully I can get 6th to keep pulling. The chart says when I shift into 6th after topping out 5th....I'll be right around 4000-4100 rpms in 6th....that should be enough to keep pulling...hopefully the front doesnt try to lift. If it does Im just going to have to abort the mission. (Houston, we have a problem!)
I have been wondering what all I can do to make the car more stable at high speeds(150+)
I am good at working with aluminum...I wonder if making a belly pan for it would help at all.....
Old Aug 7, 2004 | 12:26 PM
  #17
2001 B4C's Avatar
is your speedo corrected for your gears?
Old Aug 7, 2004 | 08:49 PM
  #18
stone4779's Avatar
yep
Old Aug 9, 2004 | 11:08 AM
  #19
SteveC's Avatar
From: Poway CA, where GOD and the sun always shines
Originally Posted by PAGregSS
Z28s are speed limited at 120 due to the 16 inch tires that are not Z speed rated.
Totally incorrect. My 2001 Z28 came with "Z" rated tires, and on a dyno jet, reached 157MPH.
If your vehicle came with NON Z rated tires your speed limiter was set to 117 MPH. The vehicle can not be produced from the factory with speeds exceeding the tires rating.
SteveC
Old Aug 9, 2004 | 12:43 PM
  #20
ACE1252's Avatar
Originally Posted by SteveC
If your vehicle came with NON Z rated tires your speed limiter was set to 1117 MPH.
SteveC
I want that car!!!!!
Old Aug 9, 2004 | 01:52 PM
  #21
SteveC's Avatar
Thumbs up Re: Engine Cuts at 120
You're too tuff killer
SteveC
Old Aug 11, 2004 | 09:49 AM
  #22
ACE1252's Avatar
lol
Old Aug 12, 2004 | 01:43 PM
  #23
MustangEater82's Avatar
For what its worth... v6s came with 235/55/16s Eagle GAs(otherwise known as eagle GAYs) and are limited to the 120 area. I think its really 118, but who really cars?
Old Aug 12, 2004 | 01:44 PM
  #24
rokudan's Avatar
Yeah, who cares.. I just want the speed limiter gone!!! The cars pull up real well to that cutoff, then bam!!! Game Over...
Not cool...
Old Aug 12, 2004 | 06:40 PM
  #25
1stls1's Avatar
Why would a v6 need a limiter? J/K
Old Aug 12, 2004 | 08:03 PM
  #26
CoUnTryMuZiCZ28's Avatar
Shifting in to 6th gear at full throttle will slow you down.. 5th is all you got.. Unless you have some good power to push that 6th gear ratio your slowing down in 6th.
Old Aug 13, 2004 | 05:47 AM
  #27
disco192's Avatar
thats funny.... my car can hit 180+... not that i would know or anything
its kinda hard to calculate how fast you are going when the needle is pegged for 10 seconds and still pulling.
Old Aug 13, 2004 | 06:35 AM
  #28
If you have enough power you can push it.. But other wise on any bolt on car or even bolt on with a small cam cant push it..
Old Aug 13, 2004 | 08:22 PM
  #29
CRZYPWR's Avatar
Never went 150 mph ... and now A4 - 3800 stall and 4.10 gear - never will haha.
Old Aug 13, 2004 | 11:54 PM
  #30
trackbird's Avatar
http://home.columbus.rr.com/trackbir...no%20small.jpg
That is my 2002 Z-28 doing a 3-4-5 gear pull on a dynojet. It shut off at 158.1 (the computer said 162 when I had the limiter removed), so it appears to be a slight speedometer error and a 162 mph limiter. I had the Eagle RSA's (really slide around or really suck a$$, not sure which) on mine as well (245/50-16).
Have fun and be safe!
