Engine Cuts at 120
Old Aug 5, 2004 | 08:47 AM
rokudan's Avatar
Engine Cuts at 120
So I had some open highway last night and I decide to open it up and see how it goes.. Once I hit about 120 the engine starts surging like it is speed limited.. I thought the speed limiter was set higher than that??
Old Aug 5, 2004 | 08:59 AM
6speedZ28's Avatar
Re: Engine Cuts at 120
If your car didn't come with the Z-rated tire option then I believe the speed limiter was set to 120mph.
Old Aug 5, 2004 | 09:14 AM
PAGregSS's Avatar
Z28s are speed limited at 120 due to the 16 inch tires that are not Z speed rated.
Old Aug 5, 2004 | 09:28 AM
6speedZ28's Avatar
Wrong, you could indeed get a z-rated 16in tire option on the Z28. They came with P245/50/ZR16 Good Year GSC's. Those cars were not speed limited to 120mph. The cars that were came with A P235 series tire, they were Good Year RSA's.....they were not z-rated.
I believe it had something to do with the gear ratio. The auto cars with 2.73's were speed limited, where as the auto cars with 3.23's got the z-rated and the 6 speed cars also got the z-rated
Old Aug 5, 2004 | 09:29 AM
rokudan's Avatar
Any idea what someone would charge to program the pcm to remove that?
Old Aug 5, 2004 | 09:38 AM
sixspeedfirebir's Avatar
A hypertech programmer can do it, but that and gears are about the only things its good for, unless you have an A4 then you can change shift firmness and shift points.
Old Aug 5, 2004 | 01:29 PM
martinss01's Avatar
ummm... id get z-rated tires if you don't already have them before doing this.
Old Aug 5, 2004 | 01:42 PM
rokudan's Avatar
Definitely... Step Dad manages a tire store, so I get tires at cost, typically half what you would pay retail.. So Tires are on the agenda...
Old Aug 5, 2004 | 09:58 PM
1stls1's Avatar
I bought my car used, but it had 245/50/16 and 3.23 gears. So far she has been up to 140 w/ no mods to the computer.
Old Aug 5, 2004 | 11:42 PM
2001 B4C's Avatar
159 my car has no speed limiter. my car goes untill it hits the rev limiter at 159 and yes, i know this first hand
Old Aug 6, 2004 | 02:08 AM
roadkillZ28's Avatar
more info here .... if u need
http://web.camaross.com/forums/showt...=speed+limiter
Old Aug 6, 2004 | 06:03 PM
stone4779's Avatar
same here....
Old Aug 6, 2004 | 11:15 PM
StylezZ28's Avatar
umm w/o a speed limiter i would thing an M6 would go much faster then 159... i got to 155 and still had some more of 5th and 6th to go..
Old Aug 6, 2004 | 11:25 PM
Knowklew's Avatar
i hit 150 no problem.......
Old Aug 6, 2004 | 11:56 PM
2001 B4C's Avatar
yeah, i belive a 6 speed with 3.42 gears has a top speed of 163 or somewhere around in there
