electric cut-outs
Re: electric cut-outs
They usually come with all the parts you need to install.
Many of of our supporting advertisers carry them, check out some of them.
https://www.camaroz28.com/misc/vendorindex/
www.quicktimeperformance.com
not sure if you are clear on what it is:
an electric cutout actually describes only part of what is commonly known as a cutout. first there is the Y that is welded into the exhaust pipe before the muffler/cat, this Y has a flange on one outlet which can be capped or uncapped to allow free flow of exhaust.
the "electric cutout" part of the equation is a separate unit that bolts to the flange of the Y. it has a butterfly valve which is opened by a motor.
QTP sells a complete kit. here's the install on my car. http://www.stealthram.com/qtpcutout.html
I have a DMH cutout. It worked great when I got it back in April, then it became stuck in the closed position a couple of weeks ago. I crawled under the car and saw that the wires had been melted by the hot exhaust. This was actually my fault because I should have routed the wires through the rubber grommet under the passenger seat instead of going in under the back passenger seat.
A few days ago I heard a loud clunk from the car after I drove over a bad bump. I looked in the rearview and saw something fly out from under the car. So I pulled over and started to crawl under the car. The electric motor had actually snapped off of the butterfly plate and was in the middle of the road.
So now I have to call up DMH and b!tch at them, I think the part has a 1 year warranty though.
I used a McCord for two years until the motor started going on it. I now have a DMH and it is an excellent piece. The only problem I had with it was that some of the bolts came loose and I had to locktite them. The DMH comes with a 4 year warranty.
DMH. Never a problem in the past 8 months. Love it. Its got like a 4 year warrenty or something like that. The guys who makes the DMH cutout is very reliable too.
dmhperformance.com
dmhperformance.com
Sorry to post my question on here but, I to am looking for some cutouts. My exhaust is stock accept for the Loudmouth catback. Will I need 1 or 2 cutouts? I guess DMH and QTech are just as good as eachother? Also what size will I need? It goes all the way to 4''. Later on I will be adding SLP longtubes to the mods on the car so I dont know if that will make a difference in size or anything. Im so lost, Thx a bunch guys.
Originally Posted by Onez4u2bn
Sorry to post my question on here but, I to am looking for some cutouts. My exhaust is stock accept for the Loudmouth catback. Will I need 1 or 2 cutouts? I guess DMH and QTech are just as good as eachother? Also what size will I need? It goes all the way to 4''. (Remm. Mine is stock accept for catback)
Originally Posted by lil_mikey69
Well, I think you usually install the cutout before the catalytic convertor, so you would only need one at that point.
A cutout on an LS1 car will be installed in the I pipe after the Y-pipe. People tend to put them under the rear seat area. Stock pipe is 2 3/4" aftermarket catbacks come with 3" pipe so a 3" cutout is what you need in either case.
On rare ocassions some put dual cutouts in the y-pipe after the cats. Then you'd need 2 1/2".
tdigger9899
Sep 7, 2015 10:56 AM
