EGR valve, can you take them off?
Old Apr 24, 2003 | 09:01 PM
longgunn's Avatar
Can you take the egr valve off? Is it good or pointless to do? How do you work with the computer if you do take it off? What do you do when you get an LS6 intake? haha lots of questions
Old Apr 24, 2003 | 10:44 PM
bombd84's Avatar
I am also interested inthis answer. I own a 99 and was looking at getting a ls6 intake. What else will I need to run it without egr. Will a ses light show up?
Old Apr 26, 2003 | 02:31 PM
longgunn's Avatar
Anyone?????
Old Apr 26, 2003 | 03:08 PM
sleeperZragtop's Avatar
OK....the EGR IMO opinion is useless...I deleted mine....for those of you that want an LS6 intake some do have the EGR built in...the EGR is only good for emission, cleaner air and crap. You will not pass any emission test once you delete this also you'll throw a code..no big deal..delete he code as well. The upside to deleting the EGR is that it wil clean up the engine bay quite a bit and your internals...believe it or not. You'll notice when you remove the intake you'll see quite a bit of black crap around the ports...that's caused by the EGR. You will not gain any hp at all...so the choice is yours...alot of guys delete it.
good luck
Old Apr 26, 2003 | 05:44 PM
longgunn's Avatar
Do you just delete the code once and it never returns or will the code keep comming back? Also, doesn't the EGR vavle help cool the engine by cooling the air that circulates through it?
Old Apr 26, 2003 | 06:53 PM
Once you delete with lS1 edit or Predator it will not come back...as for the cooling theory..good question, but I don't think so...
Old Apr 27, 2003 | 02:33 AM
dmnall's Avatar
EGR Cooling the air that circulates it ?? No, EGR is short for Exhaust Gas Recirculation, which in a nutshell takes the unburnt fuel that exits through the exhaust and forces it back into the intake manifold to be reburned..
If your car came with egr and you want to get the LS6 Intake, your best bet is to buy an LS6 intake with egr, especially if you live in a state where you have emission checks (i.e. Like CA with Smog Inspections).. If you don't have smog inspections, then get an LS6 intake w/out egr and then have a shop with LS1 Edit, reprogram your computer to actually ignore the egr code...
Old Apr 27, 2003 | 07:15 AM
amood's Avatar
Actually your first paragragh describing the EGR is innacurate. The Egr recirculates exhaust into the A/F mixture during warm up to reduce combustion temp. The "logic" behind the idea is to cut down on nitrogen oxide compounds for the couple of minutes that warm up combustion conditions exist. Afterward the exhaust is re-routed directly to the exhaust manifold for the purpose of reducing hydrocarbons (unburnt fuel).
Old Apr 27, 2003 | 10:59 AM
longgunn's Avatar
Ok, so since I live in MI and care nothing about emissions, if i buy the LS6 intake and take off my EGR, will it hurt my car at all?
Old Apr 27, 2003 | 11:49 AM
JimMueller's Avatar
It won't hurt the car. You'll just get an SES. If you have access to an OBDII scanner, you can clear the code but it'll come back. You'll need to have the DTC status changed in the PCM to prevent this recurring SES.
Like others have stated, you can buy the GM LS6 intake which doesn't offer EGR compatibility, or you can buy one modified buy a vendor and keep your EGR.
You'll also need a block-off plate for the EGR bung on your passenger manifold/header.
Old Apr 27, 2003 | 01:18 PM
longgunn's Avatar
Great, thanks for all of your help
Old Apr 28, 2003 | 02:14 AM
dmnall's Avatar
Well I guess I learned something new about the useless EGR system.. What I had posted, I was told in the past by 4 different mechanics and 2 smog techs... So I guess they are wrong as well... Oh well, in my opinion EGR sucks *** anyways and I am glad that my Z and my 68 C10 (which I am going to be picking up a Short Fleetside Bed this upcoming Saturday) does not have egr...
Charlie
Old Apr 28, 2003 | 04:32 AM
AL SS590 M6's Avatar
Moderator
ACTUALLY what you are describing is the A.I.R. system and it's fresh filtered air into the exhaust stream.
The EGR system recirculates exhaust gasses into the intake to be reburnt at certain cruise conditions.
They are both to reduce emissions A.I.R. at startup (that's the electric motor noise that you hear for a little while right after you start your car) and EGR at cruise.
And both can be done away with in none emission testing states with proper computer tuning.
Old Apr 28, 2003 | 04:37 AM
agent_51's Avatar
This man is entirely correct.
Old Apr 28, 2003 | 05:38 AM
amood's Avatar
Sorry about the confusion but my description of the EGR in the way that it works IS correct. The fact that I needed to wake up a little more before posting is the reason why I confused the routing issue of the EGR with the AIR system. By mixing the two system functions I did confuse the truth there. So, I'll lay them both out to square myself away on this subject for the original and subsequent "posters".
The EGR DOES recirculate exhaust into the intake air during warmup to reduce combustion temps. for the reasons I gave at the first. After that it is metered into the intake air depending on operating conditions.
The AIR system feeds fresh air into the exhaust stream either at the manifold or at the cat. conv. depending on operating conditions (hot/cold) for the express purpose of burning....or converting..... unspent fuel in the exhaust. It pumps fresh air into the manifold when cold...... and the cat during normal operation temps. Tricky though;----the AIR system is also credited with helping to warm up the cat to the proper temp range during warm up.
So there it is in it's simplest form. The EGR essentially cools combustion temps for emmissions purposes----
and the AIR heats up the exhaust temps for the same cause.
How's that? I'm still sleepy even NOW.....but I'm pretty sure I paid better attention to what I was saying!!!
14
Aug 11, 2015 12:03 PM
Jlo
Jul 29, 2015 03:52 PM
RX Speed Works
Jul 24, 2015 02:25 PM
HectorM52
Parts Wanted
Jul 19, 2015 08:55 PM
Dark Zeiro
Jul 19, 2015 08:25 AM
