egr mod ....
Old Mar 3, 2008 | 06:17 PM
hughett17's Avatar
Question egr mod ....
i done the mod and finally got all the vacumes fixed so now its not suckin air from nowhere....BUT...where did all my bottom end power go? it has nothing now on botton end ...mid and top end are the same ......is this the side effect to doing the egr mod?
Old Mar 3, 2008 | 07:03 PM
gilg99ss's Avatar
Try resetting the computer. Disconnect the battery for about 15 mins, and see if that fixes it.
Old Mar 3, 2008 | 08:56 PM
hughett17's Avatar
i thaught the newer model cars automatically configured or "learn" new things or how ever you put it ? with out resetting the computer
Old Mar 3, 2008 | 09:03 PM
Bayer-Z28's Avatar
^ resetting the computer for 5+ seconds still 'erases' drive info... But the LSx platform learns within seconds.. -They do not require a full drive cycle like the 3rd gens did.
Old Mar 3, 2008 | 09:13 PM
hughett17's Avatar
i dint think so ..but ill still try it
Old Mar 3, 2008 | 09:17 PM
Bayer-Z28's Avatar
Cheap and easy first.. if it didn't work, it didn't cost you anything.. Ya know? Other than that, I have no idea what would cause a drastic low end performance loss.. Unless you may have forgot to plug the EGR valve back in or something. -Even that wouldn't do it, IMO..
Old Mar 4, 2008 | 07:29 AM
Marc 85Z28's Avatar
They do, but it's an extremely slow process, and it can only compensate so much. It's not like the PCM will detect that 427" engine you just swapped in and learn the optimal PCM calibration Best thing to do is to reset the PCM and start from the factory presets - it will learn quicker that way. Regardless, it WILL require 2 full OBD-II drive cycles to go through everything.
Mikes 1994 z28
Oct 10, 2015 07:55 AM
DelSoto
Sep 19, 2015 05:31 AM
Pwilson59
Sep 3, 2015 08:47 PM
WPHIG2
Aug 27, 2015 06:37 AM
CARiD
Jul 7, 2015 08:19 AM
