egr delete kit
Make it yourself. You can plug the intake with an expandable freeze plug from Auto Zone then get some thin steel and make the block off plates. Cut the tubes off the existing EGR with a hack saw, then pin youir blockoff plates under the existing plates. I did that multiple times. I think SDPC sells a kit for $20 or $30 too, if you just want a bolt on.
-Geoff
-Geoff
You might as well delete both the Egr and AIR systems.
here is a kit on ebay i found.
http://cgi.ebay.com/ebaymotors/LS1-C...Q5fAccessories
or you can buy them off the ws6store.com
armedtrigger
Feb 24, 2015 08:30 PM
