Don't tell me it's a head gasket......
Old Oct 27, 2003 | 12:08 AM
95TA8280's Avatar
OK I've had my Formula for about 1200 miles, and it only has like 11K on the clock. It's an 01.
I bought it about 2 months ago and they obviously changed the oil because they gotta do it before selling it....
Anyways I'm driving home from the gym and low oil light comes on. I check and it takes me 2 quarts to get it to where it should be
I don't think I'm burning oil, because wouldn't I smell it? I think to oil leak is when I drive because I havent noticed any puddles under my car....if the oil is leaking while driving could it be a head gasket, or would my gauges go nuts?
Old Oct 27, 2003 | 12:18 AM
AL SS590 M6's Avatar
Moderator
Probably a stuck PCV valve. Replace it and top it off with oil then keep an eye on the oil level.
Old Oct 27, 2003 | 11:01 AM
6speedZ28's Avatar
Its 5.5 qts big shooter. Not 7.5.
Old Oct 27, 2003 | 12:07 PM
dis3as3d's Avatar
6speedZ28 is right its 5.5 quarts, dare I be the first to bring up piston slap?
Old Oct 27, 2003 | 12:23 PM
bond449798's Avatar
OIL
Yes 5.5 is correct where did you hear it was 7.5 ?
Old Oct 27, 2003 | 12:53 PM
Capn Pete's Avatar
Maybe what happened is they only put in 1 jug of oil (4 quarts) instead of a full 5.5 quarts?
Old Oct 27, 2003 | 01:46 PM
6speedZ28's Avatar
Around here a jug is 5qts.
Old Oct 27, 2003 | 01:52 PM
Capn Pete's Avatar
Oh, OK..................see what us stupid Canadians know?! Up here, a jug is 4 litres, which (I think ) is close to 4 quarts? (or 1 gallon, which is 4 qts, right?).
I know I need 3 jugs for every 2 oil changes, because I basically use 1 and a half jugs per oil change.
Old Oct 27, 2003 | 01:58 PM
Knowklew's Avatar
Originally posted by ss00
They may have only put 5 quarts in it after it was changed instead ot the 7 1/2 quarts that are required.
6speedZ28's Avatar
I'm sorry, I didn;t notice your Canadian handicap before I posted
Old Oct 27, 2003 | 03:57 PM
rncotton's Avatar
Mobil 1 comes in 5 quart jugs now. I think the book calls for 5 quarts on an oil change, but mine takes a full 6 quarts.
Of course, I let mine drain for 30 minutes. If they do a "10 minute oil change" then it probably does only take 5 quarts.
Old Oct 27, 2003 | 04:21 PM
6speedZ28's Avatar
Book calls for 5.5qts if you change the filter too. Only 5qts if you drive an LT1.
Old Oct 27, 2003 | 06:26 PM
CPFarhood's Avatar
Re: Don't tell me it's a head gasket......
I can burn 1.5 quarts of oil in 1200 miles if i beat on the car badly the whole time. I think according to GM 1 qt per 1000 miles is not unacceptable oil consumption for an ls1.
Old Oct 27, 2003 | 09:51 PM
95TA8280's Avatar
If they put in not enough originally, why did the low oil light come up after 1200 miles?
Piston slap at 11K?
Old Oct 28, 2003 | 10:20 AM
Capn Pete's Avatar
Piston slap at 11K?
Yep, I've had it pretty much since day one .
Roadie
Feb 16, 2015 10:34 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Brandon Wittmer
Dec 7, 2014 12:15 PM
