do SLP headers bang the floor board?
I thought it was just FLP's that do it...cause im hearing alot of banging now...could it be my torque arm??? I just noticed it alot more after my stage 3 clutch...could it be im not fully used to driving it??
Sometimes the Y-pipe will hit the floor board on the SLP headers. You'll have to loosen the clamps and use a block of wood to pry the Y-pipe down then retighten everything. Also check to see if your tranny mount, torque arm mount, etc are tight.
slp headers hitting floor
I have slp longtubes and high flow cats, and have the same problem. Only its they y pipe hitting the drivers side floor not the header. I'm gonna try the 2x4 trick. ( unbolt the y-pipe and cats, shove a short piece of 2x4 between the floorboard and the y-pipe, retighten all the bolts, and then knock the 2x4 out)
jim88iroc305
Aug 13, 2002 09:24 PM
Wilson
Jul 21, 2002 05:08 PM
