do the the massair meter ends work?
Old Jul 1, 2002 | 09:03 PM
phil1001's Avatar
Post do the the massair meter ends work?
do the mass air meter ends really work, they claim 10hp. is this accurate?
2000 black WS6 6speed
318 RWHP 322 RWTQ stock
best et: 12.90 with the drag radials and stock 3.42 gear.
bestmph: 109.72 first time out, no mods, on the street tires
Mods: centerforce dual friction clutch, moser 12 bolt w/4.10's
BFG dragradials, PRO 5.0 shifter
whats next: put the borla on, take baffles out of WS6 hood, tb bypass, et streets
hopeing for 12.60's
Old Jul 1, 2002 | 10:33 PM
nikkev's Avatar
Exclamation
It depends on the car,some gain and some lose.What they do is make the car run a little leaner and therefore you make more power.However,if the car runs too lean then you get knock retard which makes you lose power.I think they work better on the 98/99's than later models since we tend to run a little rich stock.Good luck.
Kevin
1998 Black Z28 A4
-------1/8-------
8.584 @ 83.64 MPH
Taylor 10.4mm wires,!EGR,!FRA,SLP Lid,MAF Ends,Manual Fan Switch,and Dynomax Cat-back
BMR STB and Sub-frame Connectors
Pics
[This message has been edited by nikkev (edited July 01, 2002).]
Collector Car
Jan 5, 2015 10:58 AM
Jazsun
Dec 29, 2014 12:14 PM
ChrisFrez
Dec 28, 2014 02:25 PM
