diablo question
Does anyone have any experience with these programmers? I just purchased one and I'm not getting results with the transmission programming.
Missingz
2 of my friends have purchased these programmers and 1 woulndnt even take in his car and the other had the same problem that it sounds like you are having. They both sent them back. I dont think they have worked there bugs outn yet. Back to the drawing board. |
What do you want to do?
Shift time -25% Shift pressure +25% Everything works for me. :) |
Mine worked fine from the very first time.
I was under the impression to increase shift pressure that it needed to be set on -25%. I really dissapointed with it. How stiff and how quick are the shifts? Will the tires chirp at WOT while shifting into 2nd gear? I'm just trying to get an idea at what I should be expecting from this programmer.
Well, since I have a Yank 3000 the shift are still a little soft.
But, compared to friends with the same TC and no programming my car shift much faster and harder. I think it denpends on what kind of tires you have,on breaking the tires loose between shift. (My car doesn't, even with the n2o) |
