Cutting out the bottom of air box
Old Oct 22, 2002 | 08:34 AM
Quiksilver's Avatar
I decided to cut out the bottom of my air box so the cold air going to my radiator is also gonna feed my motor, just like the all the overpriced cold air kits. What tool should i use i havent looked at it very closely yet but would like it to be a clean cut even though it out of sight. its gonna be fun constantly cleanin my filter but it should help it breath more especially on the hiway. What tool?
Old Oct 22, 2002 | 09:00 AM
treywright's Avatar
ummmmm.......
try using a dremel tool..... just draw a line where to cut and dont shake when your cutting....... it should be a clean cut..... i think that would be good enough...... i know a friend did that.....
Old Oct 22, 2002 | 09:13 AM
Z-Attitude's Avatar
Jig Saw
Dremel is the best. I used a jig saw since I did not have one then sanded it some. Later>>>>>>
Old Oct 22, 2002 | 07:10 PM
fbird95's Avatar
I used a utility knife. make sure the air silencer and that other plastic peice the box slides onto go inot the trash too.
Old Oct 22, 2002 | 09:48 PM
2002Z28SSConv's Avatar
I used a cutoff wheel on my bench grinder. It came out real nice.
Old Oct 22, 2002 | 11:41 PM
TA2001's Avatar
My first mod.. free ram air..
http://www.ls1info.com/article.php?sid=16
I used a knife. dremmell would be better.
Old Oct 23, 2002 | 08:49 AM
FirehawkNS's Avatar
I used a Dremel. Worked great and came out very clean.
Old Oct 23, 2002 | 11:38 AM
ponch333's Avatar
I scored it with a knife and broke off the plastic with pliers. It wasn't a clean "pretty" break but who the hell is gonna see it!
Old Oct 23, 2002 | 11:54 AM
bbentley40's Avatar
I used a dremel but I kept having cutting wheels break so I ended up using a different bit that cut pretty rough. Then I just took the sander bit and smoothed it down real nice.
95chwagon
Jan 13, 2015 09:19 PM
TitoPR221
Parts Wanted
Jan 10, 2015 09:21 AM
formula218
Dec 2, 2014 04:27 PM
