Corvette FRC's
Hey, I just ordered a set of FRC's from Dal, I got them for a 99 C5. Did I order the right ones? What has to be modified to get them to fit? Thanks guys!
Corvette Fixed Roof Coupes?
I just figured it out...fuel rail covers. In Corvette people lingo, FRC=Fixed Roof Coupe. It's a C5 hardtop. Is it common to abbreviate "fuel rail covers" like that? I had no idea what you were talking about. |
You got the good ones. The newer ones will work too, but more cutting. Since all cars are made a little bit differently, you mofifications will differ from install guides and what not. You will need to cut to clear the AIR tubes, the oil dipstick, and the throttle cable plate.
Originally posted by Ferocity02 You got the good ones. The newer ones will work too, but more cutting. Since all cars are made a little bit differently, you mofifications will differ from install guides and what not. You will need to cut to clear the AIR tubes, the oil dipstick, and the throttle cable plate. |
