Corsa wont sit right
I got my Corsa system installed, and it sounds awsome. I got every thing lined up as best I could, but after a few days of driving, it all shifts around on me. I line the tips about an inch or so from the bumper, but they shift up and hit the bumper every time. I have adjusted them 4 times now. anyone got an idea short of getting everything welded?
Something wrong in terms of the clamps...are you torqueing them to 37 ft/lbs. ?? Did you overtorque them ?? Is your torque wrench accurate (good quality ?) I torqued mine to 40 because my wrench is older and the spring is probably weaker but my system does not loosen at all. Talk to Corsa before you weld because I think it may void the lifetime warranty !!! Watch what advice you take before acting on it.
