cooling
Old Mar 13, 2005 | 06:40 PM
blu02byrd's Avatar
cooling
I have a few questions about cooling for an 02 trans am, first off can anyone recommend a transmission cooler for the 4l60? and secondly i've heard that switching to a 160 degree thermostat is no good without a manual fan control switch i have a programmer that lets you reset the computer to a lower temperature rating i really don't want to install a manual fan but i'd like the car to run colder.
Old Mar 14, 2005 | 08:04 AM
teke184's Avatar
Re: cooling
the "a 160 degree thermostat is no good without a manual fan control switch" is
you will benefit form the lower stat whenever you are driving. the only time the switch comes in handdy is at the track when you are sitting still, ie...no air over the radiator.
when sitting in traffic the stock settings are more than addiquat to keep the engine out of danger.
as for lower fan settings, they are helpful but not needed either. since you're car will be operating with them off while driving around. the only time they will come into play would be traffic...and who cares about the extra 5hp when sitting in rush hour traffic?
the fan settings can help at the track as well, but is still no totally needed.
put the stat in, and since you have the programmer, change the fan settings to 185 on, and 180 off...or so...you'll be fine
93 RedBird
Nov 15, 2015 08:24 AM
CARiD
Sep 30, 2015 05:44 AM
Bxlt1
Sep 17, 2015 08:31 AM
cmsmith
Sep 14, 2015 09:09 PM
damnyankee36
Sep 9, 2015 07:06 PM
