converter install.. IS it hard?
Old Aug 7, 2003 | 12:41 PM
chevyzman1998's Avatar
Sup guys, i have a 98 z28 and m looking to install a 2600 stall torque converter. Is this a hard task? Anything i should watch out for? Any help would be great.
thanks
Old Aug 7, 2003 | 12:48 PM
2001NBMZ28's Avatar
Here's a link that should help.
http://www.modernmusclecars.net/arti...all/index.html
Old Aug 7, 2003 | 02:54 PM
foff667's Avatar
since this doesnt necessarily look like something I would want to tackle what is the going rate for an install?
lata
Bill
Old Aug 7, 2003 | 03:13 PM
ive been told between 200-400bucks
Old Aug 7, 2003 | 03:35 PM
2001NBMZ28's Avatar
Yeah, I paid $300 here in Florida.
chevyzman: Go higher on the stall if you can, you'll want more.
Old Aug 7, 2003 | 04:21 PM
foff667's Avatar
Originally posted by robvas
You want more than 2600 stall. Trust me.
two things here if your thinking of the slp one i hear its junk....pay the extra 200 for a decent 3500+ stall.
lata
bill
Old Aug 7, 2003 | 09:32 PM
Blacker's Avatar
I would getting nothing less than a 3200 stall. The Midwest Converters are great and have a 2 year warranty. I bought a 3600 stall and it kicks ***.
Old Aug 7, 2003 | 09:42 PM
Schismblade's Avatar
That looks like a real pain in the A$$ to do.
If I ever decide to get one, i'll be sure to pay for it to be installed.
Old Aug 7, 2003 | 09:46 PM
Blacker's Avatar
It is not that bad. I had my TC installed and drivng the car in 5 hours. The local shops were going to charge me $450 for the installation. That document kicks *** and well explains the install.
Old Aug 7, 2003 | 11:15 PM
11 sec gta's Avatar
converter installs are cake in an ls1.
Do it yourself.
Old Aug 8, 2003 | 06:37 AM
RS Dragster's Avatar
Definately go bigger. I (along with 99% of the LS1 pop.) wouldn't go any lower than 3200. I'm going with AT LEAST that when time comes around for my tax return
Old Aug 8, 2003 | 12:11 PM
is going with a higher stall going to shorten the life of my trans? I am going to also install a b&m trans cooler so that should help right?
Old Aug 9, 2003 | 02:17 AM
AL SS590 M6's Avatar
Moderator
Something to keep in mind.
An automatic trans has clutches and bands in it and like a stick shift car will eventually wear the clutch out so will the automatic trans wear the bands and clutches out. And the harder that you use it the quicker it will wear out.
Yes adding a high stall will shorten the life of your automatic as it multiplies torque more and puts the car in the power band faster. But so will adding power, excessive downshifts, WOT runs. It's part of the game.
That being said. I have a 3800 rpm stall in my car and I drag race the snot out of it (over 450 passes so far). Will the trans wear out to the point of failure? Heck yeah. Will I be upset when it happens? Nope. It's a wear item and I'm wearing on it pretty hard. Would I give up the gains of a high stall for a longer life trans? Again NOPE.
Yes a cooler will help ward off excessive wear and so will frequent fluid changes.
Old Aug 9, 2003 | 02:21 AM
thank for all the info guys. I think ill end up going with like a 3000 stall or something cloes to it. What are some good less expencive brands?
Old Aug 9, 2003 | 10:17 AM
foff667's Avatar
texas-speed sells tci's from like 460 or so...thats for the 3000 stall...you could also get a 3500stall hint hint for 550 or so.
lata
bill
