Cons of Free Ram Air Mod
Old Nov 15, 2003 | 06:10 AM
  #16
2002Z28SSConv's Avatar
Originally posted by mr_muff
drive through tall grass? you take your camaro off roading.
lol, just curious as to why you would drive it through tall grass.
When I autocross, I have to drive through a field of taller than normal grass to park the car sometimes. Or if I visit somebody with a driveway that's two rows of gravel with grass down the middle... That's all.
I've only taken it to the fishing hole once. Never again.
And as far as the SSRA, I would always leave out the rubber strip that blocks the stock inlet unless you were going to the dragstrip. IMHO you could just put the same strip in a car with FRA and get the same amount of ram air effect. You will never see any gain from this mod on the dyno. However, I have no doubt that it does free up the path of air coming into the intake allowing a cooler, less restricted flow of air to the intake. Next time I go to the drag strip I think I'll make a plate to seal off the FRA mod and alternate runs with it on and off to see if there is any difference at higher speeds. Don't hold your breath though. I never go to the track. But colder weather is here, so you never know.
Old Nov 15, 2003 | 08:06 PM
  #17
v10kilr's Avatar
Originally posted by 9T8W66
There are No cons only Gains !!!!
No slam intended, but I'd like to disagree on this one.
I A-tapped my car at the track this fall trying to troubleshoot something. I noticed that with the free ram air mod, I was sitting at the staging lane with 65deg F ambient air, and the IAT was seeing 142deg F (imagine what that difference means in terms of spark advance/detonation). As someone said, at a roll with a sealed airbox you would see some gains, but at a dead stop, that's another story.
Needless to say after that, I upgraded to the WS-6 lower airbox, and used single sided 1/2" foam sealing tape and sealed the connection between my airbox and aftermarked ram air hood. IAT temps are almost a match to ambient temps now.
Just my 2 cents, but that's what you asked for.
Old Nov 16, 2003 | 06:22 AM
  #18
SFB767's Avatar
Well, after reading everyone's opinions on this, it doesn't sound like it's worth it. I kind of figured that the gains would be very minimal from removing that small piece of plastic anyway. It also rains a lot here in FL during the summer and I don't want to take the chance of getting any water in my engine.
Thanks again for the input guys.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
LT14LIFE
Feb 9, 2015 09:35 PM
rjc1629
Jan 27, 2015 10:46 AM
TitoPR221
Parts Wanted
Jan 10, 2015 09:21 AM
