Comp Cams RRs
Old May 28, 2003 | 12:32 PM
94ZRiCeKiLr's Avatar
Comp Cams RRs
anyone running the new C.C. roller rockers??? im thinking about them and i like the fact that 1) they fit under the stock valve covers and 2) they seem to be expected to make very good power for the money
anyone have them or know if they are a good idea????
Old May 30, 2003 | 11:42 PM
anyone????
Old May 31, 2003 | 02:27 AM
dmnall's Avatar
Re: Comp Cams RRs
Well I don't have them but as soon as I can spend the money on them I will.. To answer your question, I think they would be a good idea for a couple of reasons, 1. Less Friction, since the stock rockers are non roller, that is causing some HP loss, with Roller Rockers, they will cause less friction which equals more HP.. 2. A little higher lift. Going from 1.7(Stock) to 1.8 (RR) Ratio will increase HP by adding a little more lift.. Considering a tenth of a lift is not going to give you much more HP gains but where the most of the power will come from is the fact that going from Stock non roller rockers to roller will decrease friction and increase power.. From what I have read about this upgrade for LS1, 4800, 5300 and 6000 Gen 3 Small Blocks is around a 20 - 35 HP Increase, which is not bad but whenever I do this, I will add a different cam as well...
Charlie
oldschool
Feb 9, 2016 09:21 PM
MadMav
May 25, 2015 09:35 PM
carl.froehlich
Mar 13, 2015 12:38 AM
alliance12364
Mar 6, 2015 04:39 PM
Wicked
Jul 25, 2002 04:19 PM
