Clutch stuck to the floor but now woking fine
Old Jun 30, 2003 | 08:02 PM
St Pete 99 T/A's Avatar
Lightbulb Clutch stuck to the floor but now woking fine
One of my friends was using my car today and he called to tell me that my clutch got stuck to the floor and was fully engaged. He checked the fluid and said it was full but looked a little dirty. This has never happened before except once or twice where it got stuck 1/4 of the way down in heavy traffic but never to the floor. He pulled the clutch up and it gave him no more problems. Do you guys think dirty fluid could have caused the hydrolics to fail?? Worst case, is it time for a new clutch?? Thanks for the help guys! Have a safe 4th of July!
Dave
Old Jun 30, 2003 | 08:59 PM
TTT
Any Ideas please!
Old Jun 30, 2003 | 09:11 PM
ChrisLS1Bird's Avatar
Isn't this an indication that the system was not properly bled when it was refilled? Is the problem air bubbles?
Just an educated guess.
Old Jul 1, 2003 | 07:12 AM
sweet98ss's Avatar
Most likely not the clutch.... I have a 1998 ss and My pedal sticks to the floor all the time. I have read that the hydraulics are terrible in 1998-2000 f bodys. You will need to upgrade your slave cylinder in the tranny. I ordered the master and slave ...they were on sale.....email me and I can give you the name of the place and where to look for more info....It is a non sponsor so I dont want to have any problems.......
Old Jul 1, 2003 | 07:38 PM
kjlvilla's Avatar
I think there's a bulletin on this. Master cylinder problem not releasing keeping pressure on the slave cylinder. You may want to check with the dealer or an aftermarket as previously suggested. They probably have the bugs worked out that GM hasn't yet. Hope this helps.
Old Jul 1, 2003 | 08:30 PM
u8dusst's Avatar
This isnt LS1.com. Go ahead and post the URL lol.
Old Jul 1, 2003 | 10:28 PM
Think U Can's Avatar
This happened to me a few times at the track with my stock clutch.When the clutch was going out.It only happened to me when I was beating the hell out of my car.
Old Jul 1, 2003 | 10:44 PM
Stumper66's Avatar
A couple of day ago I was dropping to clutch in 2nd while going around 40 MPH. After a couple of times it all the sudden felt like there was a vacuum under the clutch and it barely returned.
After a couple of seconds it always resumes to normal.
I bet your friend was dropping the clutch alot.
Old Jul 2, 2003 | 04:06 AM
mr_muff's Avatar
only time it has happened to me is after my shift into 3rd it will stay down. only if i dump the clutch though. and it still hasn't happened when shiftinging into 2nd. i am guessing he woulda been dumping te clutch as well. you should ask him :0
Old Jul 2, 2003 | 12:42 PM
therealmagyver's Avatar
Happened once to me. I did a burn out and forgot my traction control on and when I went to go launch at the line my clutch was nothing but mush.
Old Jul 2, 2003 | 12:43 PM
PhantomTA's Avatar
Moderator
Slave Cyl is going bad..
change it now before you get stuck somewhere and have to have the car towed
liamcg97
Nov 25, 2019 05:55 PM
Biggiebound
Apr 20, 2015 07:16 AM
BPS
9
Mar 5, 2015 10:51 PM
HectorM52
Jan 30, 2015 11:08 PM
Chrisdude
Aug 14, 2002 06:30 PM
