clutch material questions
Old Dec 13, 2002 | 10:45 AM
hotrodgirl's Avatar
I would greatly appreciate some advice on which type of clutch kit I should get. What is the difference between the organic/organic surface and the kevlar/organic surface? Is the steel or aluminum flywheel better? I only run my car at the strip about 6 times a year, and this is my daily car. The only other mods I plan to do are cams and 4.10 gears.
I couldn't find this information anywhere. Thanks in advance!
Old Dec 13, 2002 | 11:07 AM
Loudmouth LS1's Avatar
Go with the Mcleod Rev-Lok II!!!!! IMO it's the best clutch setup for our cars!!! It'll hold anything you can throw at it and last a lot longer too!! You can use your stock flywheel or buy mcleod's flywheel. Check out www.thunderracing.com they have the Rev-Lok for like $420. I forgot to mention it's also one of the cheapest.
And since yours is a '98, you'll need to get the gm updated hydraulics. And make sure if it's not already done, that whoever installs the hydraulics, does the drill out mod.
Old Dec 13, 2002 | 11:48 AM
hotrodgirl's Avatar
how much more horsepower does the kevlar hold?
Old Dec 13, 2002 | 06:09 PM
ford's Avatar
Im so very sad. Im a typical guy
I was thinking about clutches then i wondered where she was from. And thought "Hmmm south lousiana, not a far drive"
Shoot me now before i do something or say something to incriminate myself.
Anyways about the clutch material.
I dont know much about Kevlar other than i heard its not reasonably streetable most of the time. It tends to clatter i believe.
Id probably go with ceramic but like i said i dont know anything about kevlar.
Old Dec 13, 2002 | 07:14 PM
number77's Avatar
what about the carbon fiber, i hear it grips well
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
BPS
9
Mar 5, 2015 10:51 PM
Newgmman
Feb 25, 2015 02:53 PM
Briah.hood
Feb 17, 2015 02:10 PM
HectorM52
Jan 30, 2015 11:08 PM
