check my cam card out , tell me what you think..what should expect?
Old Mar 14, 2008 | 07:24 PM
hughett17's Avatar
im kinda curious on how he cami is gonna sound and run along with this cam is bee hive spring and some crane cromoly pushrods anyways i really dont know how to read the cam card i was wonderin what the specs of the cam is i got it all for 300 bucks ...is that a good deal oh and also a crame powermax programer to....thankls
crane cam z- rated cam
Part Number: 1449581 Grind Number: HR-220/3241-12 (Z-CAM)
Engine Identification:
Start Yr. End Yr. Make Cyl Description
1997 2005 CHEVROLET 8 Performance cam for cars, stock or w/mild engine modifications. Use in 6000 engine. Good idle, slight chop. Must use 144832-16 valve springs. Auto or manual transmission. Good cam for PowerMax Tuner.
Engine Size Configuration
5.7 L V
Valve Setting: Intake .000 Exhaust .000 HOT
Lift: Intake @Cam 3241 @Valve 551 All Lifts are based
on zero lash and theoretical rocker arm ratios.
Exhaust @ Cam 3241 @Valve 551
Rocker Arm Ratio 1.70
Cam Timing: TAPPET @.004
Lift: Opens Closes ADV Duration
Intake 30.0 BTDC 72.0 ABDC 282.0 °
Exhaust 74.0 BBDC 28.0 ATDC 282.0 °
Spring Requirements: Triple Dual Outer Inner
Part Number 144832
Loads Closed 112 LBS @ 1.800 or 1 13/16
Open 303 LBS @ 1.270
Recommended RPM range with matching components
Minimum RPM 3000
Maximum RPM 6500
Valve Float 7100
Cam Timing: TAPPET @.050
Lift: Opens Closes Max Lift Duration
Intake 3.0 BTDC 37.0 ABDC 107 220.0 °
Exhaust 47.0 BBDC (7.0) BTDC 117 220.0 °
Remarks:
FIRING ORDER: 1-8-7-2-6-5-4-3
Crane Cams continuously improves and upgrades its cam designs. In some cases this may mean that two Crane Cams with the same part number may actually be different grinds. You must check the GRIND NUMBER stamped on the front of the camshaft and check it against the Grind Number near the top of the Spec Card. For more information on the finest available camshafts, valve train components, and automotive ignition products, visit your local Crane dealer or call the Crane Cams tech line at (386) 258-6174 or FAX (386) 258-6167
Old Mar 16, 2008 | 01:14 AM
Kraest's Avatar
Retired
Looks like a very mild cam with very lazy ramp rates.
It's not going to be a screamer by any stretch of the imagination, but you'll feel the extra power without a doubt.
Mike
Old Mar 16, 2008 | 09:22 AM
hughett17's Avatar
what kinda of numbers will this make maybe ? abround 360 - 385 rwh and would 1.8 rr help me any? i mean i couldnt pass this up with all the things listed in my sig , got it all for 300 bucks and hell the programmers is like 450 by its self so i came out alright id just like to know what kinda numbers i may be lookin at and if 1.8 rockers woud help....if my math is right with 1.8rr this would make is a 220/220 . 583/583 with 112 lsa right? would ls8 springs hadlel that
would this cam be better then the hotcam?
Old Mar 16, 2008 | 03:30 PM
Greed4Speed's Avatar
Thats because when crane started selling LS1 cams they were already 5 years behind in lobe and grind technology for the engine.
Ya, 1.8 rockers will help some if your springs will take the added lift, but for the $400+ you'll spend on them you might as well get a cam that has more lift and duration ground in it.
For a reference search on the MTI C1 "Hammer Cam." Pretty much the same grind, just the C1 was a Comp grind back in the early days.
Old Mar 16, 2008 | 04:11 PM
hughett17's Avatar
ill just get the springs my all my buddys nave this stuff laying around , which is how i got it all cheap , but ill do the springs and since the springs will hold up a while ill update the cam later, after all the other things thats on my list to do ....but what kinda power am i lookin at whith the mods that are in my sig?
Old Mar 16, 2008 | 04:48 PM
Kraest's Avatar
Retired
LS6 springs won't even handle the lift that the cam comes with on 1.7:1 rockers.
I definitely wouldn't use those if you plan on upping the lift via rockers.
On a side note, I have a cam, springs, retainers for sale in the for sale section that will blow that cam away for $300.
Mike
teal98
15
Sep 16, 2002 01:23 PM
danielbmx
Aug 27, 2002 11:11 PM
johnsocal
21
Aug 17, 2002 01:06 AM
SilverWS6
13
Aug 14, 2002 09:29 PM
newby
10
Jul 27, 2002 11:39 AM
