Check engine Light
Old Jul 17, 2005 | 09:07 PM
SpeedDemon02SS's Avatar
Check engine Light
Hey, my car is throwing 2 codes:
P0137 O2S Circuit, Bank1 - Sensor 2 low voltage
P0420 Catalyst System, Bank1, Efficiancy Below
Anyone ever have this? Are my o2's bad?
Old Jul 19, 2005 | 07:07 PM
LT-14me's Avatar
Re: Check engine Light
well, i am the king of the SES light mine has been on for 2 years strait for misc things.
Now to your problem. Yeah the bank 1 sensor 2 is the o2 sensor after the cat on the drivers side. The P0420 means your cat has either **** the bed or due to the bad o2 it can cause this code to be thrown since the o2 after the cat measures if the cat is working or not and if the sensor is bad then that can tie into your problem.
Old Jul 19, 2005 | 08:36 PM
Kataklysm's Avatar
Sounds about right to me!
Old Jul 19, 2005 | 11:09 PM
i cleared the codes, put on about 150 miles...ses is still off. car runs great...no lack of power, or throttle response. is it possible that there was just a surge in power, or a rock that could cause a trip?
Old Jul 20, 2005 | 10:34 AM
LT-14me's Avatar
More likely a short. If your o2's arent connected up properly or if moisture gets in there then it will toss all sorts of low voltage high voltage codes. Which can mean a number of things. A bad rear o2 wont mess with throttle responce at all. Just recheck the connections make sure everything is down tight and you should be good. If you get the code again then you will most likely need to replace them.
bfmv13trivium
Jan 14, 2015 09:57 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
Jan 5, 2015 07:14 PM
cmdeshon
Dec 27, 2014 10:06 AM
ro2207
Dec 4, 2014 06:18 PM
