check engine light
Old Feb 20, 2005 | 12:08 AM
SpeedDemon02SS's Avatar
check engine light
Hey,
My check engine light came on yesterday. Not flashing, so its something in the emissions. Gas cap is good, nothing is wet, good fuel. Any ideas? O2 sensor? Glitch? What would cause it to just come on?
thanks
Old Feb 20, 2005 | 04:07 AM
BirchMan98z's Avatar
Re: check engine light
A.I.R./EGR? A crinkled gasked in the emissions system can sometimes throw a useless code. Best to just scan it and find out.
Old Feb 20, 2005 | 10:49 AM
Just scaned ECU. i was throwing 2 codes: engine running to cold (due to 160 thermo), and catalitic converter not functioning properly (because engine is too cold)
my engine runs between 160 and 200 depending on outside temps, cause i havent reset the fans yet. I've had the thermostat in now for about 6 months, any reason why it woulds throw a code now?
thanks
Old Feb 20, 2005 | 12:11 PM
2001NBMZ28's Avatar
You can look up the DTC descriptions/solutions at www.gearchatter.com/
I run my fans at 184/175 and 194/185 year round with a 160 and have never thrown any codes. Can you post the codes? Just curious what they were.
Old Feb 20, 2005 | 03:03 PM
sorry, i can not post the codes, i already deleated them. ill try to look them up, and post them later.
sorry can not find the exact codes. is there anyway to retrieve them from the scanner?
Old Feb 20, 2005 | 03:37 PM
2001NBMZ28's Avatar
If you cleared them with the Predator they're gone. Hopefully they won't come back.
Old Feb 20, 2005 | 05:19 PM
ya, there gone...if they come back, ill post them, and then clear them
Old Feb 21, 2005 | 04:31 PM
Dustin@SS's Avatar
it's probably your catalytic converter. i just went to the dealership and they scanned mine and one of my catalytic converters is not flowing as good as the other. The funny thing is a GM catalytic converter cost $800 but i aint got to pay that since im still under the emissions warranty and even if I wasnt i would just go buy magnaflow or slp high flow ones for like $700 less.
Old Feb 21, 2005 | 09:58 PM
my cats are fine. in order for the cats to work properly, you need temperatures of over 200 F. and because my engine is running at 160 F, the cats are not functioning properly. all that means is that im making more HP and more pollution.
Old Feb 22, 2005 | 10:38 AM
silv3rsw33t's Avatar
Your water temperature has little to no effect on your EGT (exhaust gas temperature) If you were to hook up a EGT monitor to your hottest cylinder it should read around 900 deg. Now your A/F ratio can affect this. The leaner you run the hotter it gets or vice versa. If your throwing codes it has nothing to do with your water temp.
-Travis
Old Feb 23, 2005 | 04:03 PM
TXNC5's Avatar
Just an FYI, you can get almost all PCM DTC codes fully explained here (they are broken down by Year and Platform):
http://www.gearchatter.com
Just look for the DTC category.
bfmv13trivium
Jan 14, 2015 09:57 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
Jan 5, 2015 07:14 PM
cmdeshon
Dec 27, 2014 10:06 AM
ro2207
Dec 4, 2014 06:18 PM
