Catalytic Converter possible problem
What kind of problems will the Catalytic Converter cause. I ask because my car has started running like **** and someone told me it could be my cat. I was just wondering what some of the problems it can cause. My car is hesitating real bad .
If you don't have a scanner places like Auto Zone will read them free. Just post the code, don't worry about the description. If it's a cat you don't need to be the original owner - they're covered for 10yrs/120K.
Well those codes are:
P0151 Bank 2, Sensor 1 02 Low Voltage
P0131 Bank 1, Sensor 1 02 Low Voltage
P0101 MAF Sensor Performance
Glanced through the descriptions at www.gearchatter.com/viewforum37.php One possible cause for all three is a vacuum leak. Have you done anything to the car recently? Edit: Just read some more, looks like the MAF could be causing the other two codes. I'd make sure it's clean. Another thing you can check is the ENG SEN fuse.
ChrisFrez
Feb 15, 2015 07:49 AM
