Car running warm in 40* weather?
Old Oct 24, 2004 | 04:29 PM
LT-14me's Avatar
Hello, well my car went from running about 160* in about 45+* weather to now 210* in 35-44* weather? I have pleanty of coolant. Oil seems fine. It really started when i switched from my k&n filter to a fram filter then i wasnt able to seal the airbox totally. I was late for work and drove the car with the lid closed but the little forks on the back of the lid were slightly lifted since i wasnt able to guide them in because the fram wasnt fitting right. So i drive the car, and it was cool around 40-44* and i noticed that my temp was going up.
I figured it was because the fram wasnt allowing enough airflow through. So later that night at about 38* outside. I adjust the filter and i was able to get the lid to seal better. Drove it around for another day and the same thing. Cold windy day it shot up to 210*. i then switched back to my K&n filter with about 25k on it. (too cold to recharge it, thats why i took it off i was gunna re-oil it. but didnt get a chance to) So i place the K&n back in my SLP Lid, and the temp remains the same. Airbox is sealed nice and tight.
Now my question is WTF is goin on? Is the computer sensing the change in temps and causeing it to run warmer? Also, my check engine light has been on since one of my elec fans blew out (about 6 months ago) so the check engine light is on, and i have one fan out but those low temp #'s were with the blown elec fan.
Oil changed about 1k miles ago. Rad flush about 5k ago. Car seems to run fine. I am just worried about the temp. Is this normal for cold weather in LS1's? The last time my car ran this hot was in 98* heat during the summer. Once i get moveing the car will always cool down to 160* or so and i have a stock thermostat. But no matter how fast a drive the most it will go down is about 6-8*.
Any ideas? Maf dirty? Cold weather causeing sensors to make car run warmer?
I am really not sure what could cause my car to jump nearly 60* of running temp. Last year if i remember correctly i drove my car all winter and the temp never shot up like this.
Old Oct 24, 2004 | 10:42 PM
LT-14me's Avatar
Re: Car running warm in 40* weather?
found out what the problem was, BOTH electric fans are now dead. Does anyone know the part # for the fans? Are they one Solid piece? Or are the fans sold seperatly? Thanks
Old Oct 24, 2004 | 10:45 PM
Klypto's Avatar
LUCKILY you dont live in new orleans, my car runs 210 in 90 degree weather, would melt itself if didnt have fans
hehe
cory
Old Oct 25, 2004 | 01:05 AM
AL SS590 M6's Avatar
Moderator
Fans can be removed from the shroud seperately. But a salvage yard complete set-up might be the ticket.
Old Oct 25, 2004 | 11:03 AM
LT-14me's Avatar
Think something is shorting them out? I mean i have never had this happen. BOTH fans die? I havent seen any posts on this...so i think something in my car must be shorting them out. Fuses seem fine since i am sure if my elec fan fuse went i am sure a boat load of other things will.
Alright thanks. I am gunna see if GMparts Direct.com has them. Anyone know the part # for the fans? thanks
ro2207
Dec 4, 2014 06:18 PM
USAirman93
Nov 24, 2014 03:37 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Snoman73
Nov 17, 2014 07:22 PM
Brent94Z
Mar 21, 2002 04:44 PM
