car is much slower than it should be, what should i check?
Old Nov 8, 2004 | 07:42 PM
  #16
97bowtie's Avatar
Re: car is much slower than it should be, what should i check?
Originally Posted by 87camracer
something i would check is the o2 sensors. cheap and kinda easy to replace but will definately kill power.
another thing ive read but only read once, is that the LS1 ECU will pull timing if the gas in the tank measures below a 1/4 of a tank. something about it helping with gas mileage. dunno if thats true or not or even if you were driving with a low tank of gas that night either.
I've never heard of the PCM pulling timing with a given amount of fuel in the tank. Pulling timing wouldn't increase gas mileage unless the pcm also leans the car out, which i highly doubt.
Old Nov 8, 2004 | 10:41 PM
  #17
mebanditws6's Avatar
If you're changed plugs and the fuel filter and assuming the wires are good, a simple treatment of GM Top Engine Cleaner, which is basically Seafoam but in a spray can, may help. If you're getting timing retard at WOT, it could just be from carbon buildup.
Jason
AdsoYo
May 2, 2018 03:21 AM
ChrisFrez
Dec 21, 2014 09:47 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
ro2207
Dec 4, 2014 06:18 PM
USAirman93
Nov 24, 2014 03:37 PM
