Can my 99 SS camaro hold NOS
Old Jan 18, 2003 | 02:52 AM
T/A KID's Avatar
I have a A4 99 SS camaro, right at 60,000 miles, my motor burns just a little oil. Here are my mods Hypertech power programmer III, 160 thermostat, ported TB, Grantatelli MAF sensor, LID, free ram air mod, TB bypass, Borla Exhaust, custom Y-pipe with 02 sims, no cats, small shift kit, 2800 Vigalante Stall, hurst line lock, Strut tower brace, control arms. 3:42 gears with eaton posi and T/A rearend girdle, ok I think thats about it.
So heres my question I have had the PN 5177 NOS dry kit for about a year I don;t know if my car can handle it, I am just afraid of BREAKING OR BLOWING something up. Honestly give me your opinion on what will happen if I spray it. Can my car handle the NOS.
Thanks alot T/A KID'S brother
BTW I have no idea about how much Flywheel HP this is about without the nos or even with it.
I have ran a 8.1 in the 1/8 with slight wheelspin.
Do you guys have any idea about what type of numbers this car throws down.
Old Jan 18, 2003 | 11:16 AM
2002 NBM Bird's Avatar
I am no NAWSSSSSSSS expert by any mean, but talking to a few NAWSSSSSSSS people, they have told me that the LS1 enjoys a nice 100-125 shot. This would be a safe limit to use.
Doubt this helped, but you never know
Old Jan 18, 2003 | 11:21 AM
As for dyno #s, just skimming through your mod list, I would say you have about a little over 310rwhp off the bottle, those #'s shouldn't bother you though because the Vig 2800 cuts off .5 yet you loose RWHP. You've got a killer car, don't worry about dyno #s
Old Jan 18, 2003 | 01:24 PM
Loudmouth LS1's Avatar
Re: Can my 99 SS camaro hold NOS
If anythings gonna break, it'll be the rear if your on a sticky tire, or the driveshaft, and maybe the tranny, heard the a4's aren't too strong.
Old Jan 18, 2003 | 02:02 PM
Re: Re: Can my 99 SS camaro hold NOS
Anything else, looks like the are the most important parts to break. Part that $ucks is that he is probbaly right, the A4 tranny is a little weak, but the A4 rear is stronger than the M6 rear. Driveshafts aren't too bad eitherm they are not too expensive to replace.
Old Jan 18, 2003 | 02:06 PM
Ken S's Avatar
If everything is good condition, a d you don't lean out..and if you've been doing it for a year.. your probably safe..
Just like anything, your putting more stress and wear on components, and increasing their chances of breaking earlier.
Old Jan 18, 2003 | 02:07 PM
Re: Re: Re: Can my 99 SS camaro hold NOS
They're is no difference in the rear on the a4 and m6, it's just the a4 is a little easier on the rear, that's why they can handle a little more. But yeah, if you wanna run the nitrous and have no problems, I would buy a 12-bolt, a nitrous ready driveshaft, and beef up the tranny a lil. Then you can run it all day long and not have a problem, although the tranny may still go, not sure how sturdy they are.
Old Jan 18, 2003 | 04:16 PM
I know they have the same rear, I should have made it more clear in my post, sorry.
Old Jan 19, 2003 | 12:26 AM
It's cool
Old Jan 19, 2003 | 10:47 AM
Mikie's Avatar
Robvas gave you words of wisdom there.
Do not run platinum plugs while spraying n20.
Incorperate a good tune up while changing the plugs by jumping on a new fuel filter, air filter, tranny fluid change, and even go as far as a coolant flush.
I spray 150 rwhp shot through mine and have had no problems with the factory a4 tranny or rear.I also have never put slicks on my car or changed ratios in the gearing either. As long as you take the neccesary precautions you SHOULDNT have any problems.
I say shouldnt because there is never any gaurantees.
Old Jan 19, 2003 | 12:00 PM
Mikael's Avatar
Like me, your '99 has the suckiest injectors of the ls1 lineup. Nothing to worry about though.
Safely, 100 dry shot would be fine, 125 dry would be pushing it a little, anything more and you'll want to go wet. Switch the plugs, and buy a window switch, and go have fun.
Old Jan 19, 2003 | 12:06 PM
I'm curious what's wrong with the injectors on a '99, cause I got a '99 Z?
Old Jan 19, 2003 | 07:06 PM
PhantomTA's Avatar
Moderator
NOS?
Nos is a company
Old Jan 19, 2003 | 08:21 PM
Mikael's Avatar
I think they're around 26.xx lb/hr, compared to other years of 28lb/hr. Nothing major.
Old Jan 19, 2003 | 10:33 PM
KamaroL98's Avatar
Well, with a 125 shot nothing on my car has went out yet and thats going though roughly 20 15lb bottles...
However, with your stall, i dont know how long that poor tranny will old up with a 125 shot.. I was was going to wait until i got a bullet proof transmission until i installe a stall...
F'n1996Z28SS
Aug 23, 2023 11:19 PM
fpete1992
Dec 11, 2014 03:51 PM
Jul 4, 2005 05:00 PM
Chrisdude
Jul 24, 2002 02:25 PM
