Can i run Hypertech without reset?
Old Dec 6, 2002 | 02:16 PM
DaveGrun's Avatar
I just had my chip reflashed back to stock after my battery ran out during programming. I plugged the HPP in just to see if it would still work, it went through all of the vin checks and everything, than it said will continue programming since it ended at like 73% last time. Should I let it continue, even though i have a fully stock chip again, or is there a way to reset that, and start all over? Thanks.
Old Dec 6, 2002 | 04:42 PM
MRZ28HO's Avatar
Exclamation
I would contact Hypertech's tech line to find the true and correct answer. If you (or someone else) gueeses, you run the risk of paying for another reflash.
Old Dec 7, 2002 | 05:03 PM
chevy qc's Avatar
where's this chip thing your talking about? the pcm uses a flash memory prom that is soldered to the board, it's not a "chip". i'd just try to start over or contact hypertech and see what they suggest. i've contacted them a few times for vehicles at work and they have no problems with helping.
armedtrigger
Feb 24, 2015 08:30 PM
thenewkid
Nov 27, 2014 09:41 AM
slothgrant
Aug 22, 2002 03:01 PM
Javier97Z28
Jul 24, 2002 08:13 AM
Speeds8erM-1
Jul 18, 2002 11:36 PM
