cam a tooth off?
Old Sep 26, 2004 | 10:24 PM
Timberwolf's Avatar
cam a tooth off?
it has been mentioned maybe my cam is a tooth off (based on the numbers it's giving).
Now, with .595 lift, wouldn't a tooth off be enough to cause a valve to piston clearance issue?
Old Sep 26, 2004 | 10:39 PM
wrencher's Avatar
Re: cam a tooth off?
Could be off a tooth advanced & open & close sooner. Usually moves the power band up advanced as well, vice-versa retardarded.
Old Sep 26, 2004 | 10:42 PM
Timberwolf's Avatar
well, see this thread for my problems and see if it sounds like it could be the problem: http://web.camaross.com/forums/showthread.php?t=304350
Old Sep 27, 2004 | 02:00 AM
AL SS590 M6's Avatar
Moderator
This is just my personal opinion so take that for what it's worth. But I don't believe it would run anywhere near as good as it does if you were a tooth off. I would run crappy.
You bought this cam used. Didi you put a degree wheel on it to check the valve event timing? Maybe it was a bad grind anad that's why the guy was selling it?
Old Sep 27, 2004 | 07:03 AM
Timberwolf's Avatar
Well, that's what I Was thinking, but it's been brought up more than once now. I'm pretty confident int he way it was installed, I've done a lot of cams in my day. But If all other possibilities are eliminated, I will go back in if I need to.
Nope, unfortunately I didn't have the time or equipment. You know how late the cam came in the ballgame. I had to kind of take him at face value for now.
rideordie
Nov 5, 2019 04:52 PM
Sauced
Apr 29, 2015 08:31 AM
cmsmith
Apr 1, 2015 07:36 AM
Newgmman
Feb 25, 2015 02:53 PM
