IS this cam too big?... .649 .609??
Old Dec 22, 2006 | 07:15 PM
Bayer-Z28's Avatar
My buddy might be getting rid of his cam. -For a different one. He's got ported LS6 heads. Is this cam a smidge too big for a stock LS1?? Seems like a LOT of lift.
TSP Magic Stick V.4 -239/242 .649"/.609" 112 LSA- Too much/agressive for a DD?
I might be getting a good deal on H/C soon!!!
Old Dec 23, 2006 | 07:47 AM
Greed4Speed's Avatar
IMO, yes. But people do it. You'll need some gears to keep it in the powerband.
I'm of the opinion that most poeple overcam their engine when if they'd just do a good set up with a smaller cam while making less on the dyno they'd run just as fast or faster. Check out the grinds Patrick G on tech comes up with.
Old Dec 23, 2006 | 08:59 AM
JimboManJones's Avatar
I am not sure, but with that much duration, you might wanna measure piston to valve clearances...
I know someone with that cam, and it'd be pretty rough for a daily driver, but if you don't mind surge, go for it.
Old Dec 23, 2006 | 10:07 AM
myslowcamaro's Avatar
id be one of those people to do it just to say i have it. i would have if it was out then.
Old Dec 23, 2006 | 01:07 PM
Another downside to these big cams comes with the necessity of fly cutting.
I've talked to some local guys, and they said the MS4 isn't making anymore power than the MS3.
I personlly don't know, but I did find this:
http://ls1tech.com/forums/showthread...hlight=ms4+ms3
Off the subject, but how do you like those 5.3 PRC heads, myslow?
Old Dec 23, 2006 | 06:22 PM
i like them. never had darts or afr's to compare them to but seem to work just fine for the price.
Old Dec 23, 2006 | 07:20 PM
Bayer-Z28's Avatar
Hu... Alright them. I might just go w/ an MS3 then. I'm gonna try to scroe some heads of my buddy. I hope he sells them....
Old Jan 1, 2007 | 10:43 PM
brokeTA's Avatar
Your not gonna notice any drive ability issues between the ms3-4 they will be about the same. I dd an ms4. If you have a good tuner you won't have to worry too much about cam surge and stuff like that. I have a very slight amount of surge at idle only. You can't hear it through the exhaust but can see it on the tach. It still gets right at 20 mpg, and I also have some ok patriot heads with about 12.85 compression (probly helps some). The car makes awesome power clear across the board.
Old Jan 1, 2007 | 11:42 PM
SilverTurtle's Avatar
I've got a T-Rex 243/249, .608/.613, 110.2lsa and its REALLY close to the pistons, but just clear enough to keep it from slapping... I'd highly recommend making sure that your piston clearance is ok if you go with that cam... and with the right tuning, you should be just fine daily driving that cam... but it will probably take some tuning in the midrange and low end to get rid of the surge.
Sergio
Jan 27, 2016 04:27 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Redbird
Jul 20, 2002 06:08 AM
NJ SPEEDER
Jul 19, 2002 10:22 PM
