Cam swap packages
Old May 14, 2005 | 07:48 AM
camaronewbiess's Avatar
Cam swap packages
I notice on Thunderracing you can get the
camshaft package with single valve springs and your choice of retainers
or
camshaft package with dual valve springs but no choice of retainers
Do dual springs not use retainers? If this is the case would it be better to get the dual springs package for $799 or the single springs package with titanium retainers for $729? 224/224 114lsa cam. Also the dual springs kit allows you to upgrade to comp cams spring kit from crane cams kit for an additional $175. What would the benefit be in doing that? Thanks for your time.
Old May 14, 2005 | 09:28 AM
teke184's Avatar
Re: Cam swap packages
i think dual springs on a TR224 is a bit overkill
the singles should be fine.
Old May 14, 2005 | 11:51 AM
thanks for the reply, Would you recommend the titanium retainers as well?
chuyz28
Feb 19, 2015 12:50 AM
chuyz28
Jan 15, 2015 04:14 PM
Queens94z28
Dec 20, 2014 09:11 PM
chuyz28
Nov 25, 2014 11:14 PM
Queens94z28
Nov 20, 2014 06:03 PM
