cam question
cam question
I want to install a new cam for alittle more hp. Would new heads and rods ect. really be needed? The only mods I really have is a SLP lid, GMMG cat back, Pacesetter LT's, and a TSP catted Y, (working on getting a SLP LS6 intake). And what size cam would you recommend for my '98 Z?
Re: cam question
heads are not needed at all. the stock casting flow pretty freakin well. you'll make more hp if you did heads...but it will still run fine after a good tune.
i suggest a TR224 cam or so
nothing really special is needed other than valve springs, should net you around 370-390hp after a tune (with your mods maybe more) and will be streetable
Re: cam question
I was looking at the TR224 cam, but ive also been looking at the comp XER cam , it has 224/230 duration and .581/.588 lift. Does anyone here have that cam, and which one would make more power? I know Thunderracing has awesome custom grind cam, so is there any reason to believe the TR224 would make more power then the XER cam?
Re: cam question
Ok, so how does this package from Thunder Racing sound:
CamPk-S = 224/224-114
26918 valve springs
reuse stock retainers
TR stock length pushrods (7.400)
new gaskets
Seems to be in a good price range. But I am confused by the cam size. There was a 224/224-114 and a 224/224-112
I really don't know much about cams. My goal is to reach alittle over 400hp. Tell me what you think about this package, I saw it on ThunderRacing
26918 valve springs
new gaskets
oldschool
Feb 9, 2016 09:21 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
