which cam for A4
Old Jul 16, 2004 | 09:44 PM
TXZ28LS1's Avatar
which cam for A4
im looking to do a cam swap later on. im deciding between 2 cams for my 2000 A4. my current mods are mti lid, hooker headers, dynomouth exhaust, free ram air . i have 3.73 waiting to go in for the 2.73. but the 2 cams are from mti and comp.
mti cam is the 224/581/114
comps cam is the xe275 222/224/566/568/112
which one would be better and give me raw power. i was also looking into the tr224/561/114. but im deciding between the mti and comp. thanks
Old Jul 17, 2004 | 10:16 AM
MISOMWS6's Avatar
Well as you can tell they are pretty similar cams with the mit one having higher lift, i'm really not shure what the diffrent lift specs will do for you but you should stay with a 114LSA on a a4 whatever you do. There is just to much info that I don't know about cams to help you pick the "best" cam for your needs. BTW: you should look into getting a stall before the cam.
Old Jul 17, 2004 | 03:19 PM
JGKadell's Avatar
Go with a Futural Motorsports cam, they seem to be making the best power these days
Old Jul 17, 2004 | 07:17 PM
TXZ28LS1's Avatar
thats what ive noticed. alot of positive feedback from futrals cams. ill definitely look more into them. but i dont think im gonna drop a stall on my fbod. i dont even think ill even take it to the track. im just actually trying to be atleast 370ish as far as power. thanks...more replies will be definitely appreciated.
Old Jul 17, 2004 | 08:48 PM
V6toZ28's Avatar
If you're not going to put in a stall, anything higher than a 220 may be problamatic for you ... particular if you get one with extreme ramp rates ...
Old Jul 18, 2004 | 08:25 AM
JGKadell's Avatar
I agree, the cam without a stall is not a good choice unless it is a small cam.
The stall and cam should be matched to perform the best.
They have not updated their site yet. I emailed them for cam info and this is what the sent me.
FM-F2-112 Futral Motorsports Custom Grind Camshaft - 224"/224" .586"/.586" 112LSA aggressive profile with a 1800-6600 RPM range, fair idle $ 399.99
FM-F2-114 Futral Motorsports Custom Grind Camshaft - 224"/224" .586"/.586" 114LSA aggressive profile with a 1800-6600 RPM range, good idle $ 399.99
FM-F4-112 Futral Motorsports Custom Grind Camshaft - 226"/226" .575"/.575" 112LSA aggressive profile with a 2000-6600 RPM range, fair idle $ 399.99
FM-F4-114 Futral Motorsports Custom Grind Camshaft - 226"/226" .575"/.575" 114LSA aggressive profile with a 2000-6600 RPM range, fair idle (See track run of this cam in a cam only setup) $ 399.99
FM-F5-112 Futral Motorsports Custom Grind Camshaft - 224"/228" .586"/.581" 112LSA aggressive profile with a 1800-6600 RPM range, fair idle $ 399.99
FM-F5-114 Futral Motorsports Custom Grind Camshaft - 224"/228" .586"/.581" 114LSA aggressive profile with a 1800-6600 RPM range, good idle $ 399.99
FM-F6-112 Futral Motorsports Custom Grind Camshaft - 226"/230" .576"/.591" 112LSA semi-aggressive profile with a 2000-6800 RPM range, rough idle $ 399.99
FM-F6-114 Futral Motorsports Custom Grind Camshaft - 226"/230" .576"/.591" 114LSA semi-aggressive profile with a 2000-6800 RPM range, fair idle $ 399.99
FM-F7-114 Futral Motorsports Custom Blower/Nitrous Camshaft - 224"/230" .586"/.591" 114LSA aggressive profile with a 1800-6800 RPM range, fair idle, for blower/nitrous applications $ 399.99
FM-F9-114 Futral Motorsports Custom Blower/Nitrous Camshaft - 232"/236" .585"/.598" 114LSA aggressive profile with a 2800-7000 RPM range, rough idle, for blower/nitrous applications $ 399.99
FM-F10-112 Futral Motorsports Custom Grind Camshaft - 228"/228" .581"/.581" 112LSA aggressive profile with a 2200-6600 RPM range, fair idle $ 399.99
FM-F10-114 Futral Motorsports Custom Grind Camshaft - 228"/228" .581"/.581" 114LSA aggressive profile with a 2200-6600 RPM range, fair idle $ 399.99
FM-F11-112 Futral Motorsports Custom Grind Camshaft - 228"/230" .581"/.591" 112LSA aggressive profile with a 2200-6600 RPM range, fair idle $ 399.99
FM-F11-114 Futral Motorsports Custom Grind Camshaft - 228"/230" .581"/.591" 114LSA aggressive profile with a 2200-6600 RPM range, fair idle $ 399.99
FM-F12-112 Futral Motorsports Custom Grind Camshaft - 230"/230" .591"/.591" 112LSA aggressive profile with a 2500-6800 RPM range, rough idle $ 399.99
FM-F12-114 Futral Motorsports Custom Grind Camshaft - 230"/230" .591"/.591" 114LSA aggressive profile with a 2500-6800 RPM range, rough idle $ 399.99
FM-F13-112 Futral Motorsports Custom Grind Camshaft - 230"/232" .591"/.585" 112LSA aggressive profile with a 2500-6800 RPM range, rough idle $ 399.99
FM-F13-114 Futral Motorsports Custom Grind Camshaft - 230"/232" .591"/.585" 114LSA aggressive profile with a 2500-6800 RPM range, rough idle $ 399.99
Old Jul 18, 2004 | 12:43 PM
TXZ28LS1's Avatar
that sucks i cant atleast run a 224 cam. the only thing i wanted to do as far as transmission was a tranny cooler. but im still saving up. so i have time to decide. plus i need my gears first...thanks for replies jg and misom, and v6toz28
Old Jul 18, 2004 | 01:08 PM
V6toZ28's Avatar
Originally Posted by TXZ28LS1
... plus i need my gears first...thanks for replies jg and misom, and v6toz28
converter before gears. ... You'll get a lot more bang for the buck with even a mild 3200 stall than you would by going to 3:73s ...
Old Jul 18, 2004 | 09:23 PM
MISOMWS6's Avatar
Re: which cam for A4
Exactly!!!
Old Jul 18, 2004 | 09:28 PM
JGKadell's Avatar
my car went 12.2's full weight with stock gears, (3.23) and a vig 3,200, and bolt ons, mac mid length headers. Not to mention it would 60' in the low 1.6 range even on 17" nittos.
Old Jul 18, 2004 | 11:54 PM
TXZ28LS1's Avatar
Talking Re: which cam for A4
man a converter is like 700 bucks...dude theres my cam....lol...
Old Jul 19, 2004 | 12:49 AM
V6toZ28's Avatar
By the time you get done with a gear install and paying for the tuning, it's going to run you pretty close to $700.
You can pick up a Midwest or TCI converter in the $500 range. You and a couple of buddies can do a TC install in an afternoon ... gears are little more specialized - best left to pros or the very experienced.
Old Jul 19, 2004 | 06:55 PM
mullettour's Avatar
Yeah, I have done both and can tell you the stall is much easier to install. There is more to remove but it is much less precise. I installed the stall in my former camaro in the parking lot at work by myself in about 6 hours. Good tc install guide here. Sorry to not answer your question about the cam, but I never did one of those so I don't have much feedback.
Oh yeah, I picked up my stall (Vig 3200) in the for sale section here for $425 shipped to me.
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
