Cai or ssra?
Cai or ssra?
Which one would be better to get? I have heard the ssra has problems during rainfall is that true? I really want to improve my induction. I am already planning on lid, but I want something else as well.
Re: Cai or ssra?
), you just reattach the lower half and you're good to go.
i, as have hundreds of other owners, driven in VERY rainy weather. i have had no problems.
the only actual story i heard, from a confirmed wittness, was a guy drving full speed through deep water TRYING to cause a rooster tail....not something you do with a ram air scoop.
the SSRA and the cai will function identical at slower speeds, but at highway speeds the SSRA becomes a 10hp advantage over the CAI....which would you rather have?
the ssra, i believe, is a better option than the ftra...driven through a lot of rain and haven't had a problem.
don't know about any 10hp gain at higher speeds....highly doubt that, considering "ram air" is debateable on our cars...so i highly doubt that going 70 is gonna net 10hp with a lower scoop attached.
only thing i have against the ssra is that i've had some trouble with mine.....falling apart. the lower scoop had split at the seems, i tried to repair it, but it came apart again...thinking about scrapping the scoop and trying to use the plastic for something else....
i'm the only one i know that has had this problem with the lower scoop, so you might not have any troubles....
tdigger9899
Sep 7, 2015 10:56 AM
