Buying 02 Trans am? what to look for?
Old Oct 5, 2005 | 10:22 AM
  #16
NewbieWar's Avatar
Re: Buying 02 Trans am? what to look for?
ohh yea did they still put 2.73's in ls1's?
and if so... would the gear selector not allow you to goto 1rst? like the lt1?
and 3.73's how do those do for ls1's?
Old Oct 5, 2005 | 10:31 AM
  #17
JakeRobb's Avatar
Super Moderator
According to this page, it either has 2.73's or 3.23's. I don't think you can tell by looking at the gear selector on the newer cars...
Old Oct 5, 2005 | 10:56 AM
  #18
NewbieWar's Avatar
14 gallon fuel tank?
i was under the impression it was changed for the bigger after lt1...
i thought for some reason it was 17 gallons...
Old Oct 5, 2005 | 12:06 PM
  #19
JakeRobb's Avatar
Super Moderator
If my tank holds 17 gallons, then there are still four or five gallons in it when the needle hits E. I'm not planning on finding out...
Old Oct 5, 2005 | 12:27 PM
  #20
NewbieWar's Avatar
then good thing I didnt bet my friend that it was 17 gallons... lol...
the lt1's were 15 gallons w/ metal tank, the ls1's are 14 gallons with plastic tank correct?
Old Oct 5, 2005 | 01:08 PM
  #21
NewbieWar's Avatar
Fuel tank capacity 17 gal.
This is where I read that... Cars.com research says it has 17 gallon tank...
lets see if i cant get another source to confirm 14 or 17 gallons...
Old Oct 5, 2005 | 01:12 PM
  #22
NewbieWar's Avatar
All versions get a larger, 16.8-gallon fuel tank
http://www.wcax.com/global/story.asp?s=2590835
is also where i read, this...
now i know the lt1 fuel pumps were sensitive, but whats the most any of you ls1 owners have put into your tank?
Old Oct 5, 2005 | 07:54 PM
  #23
jjones's Avatar
go to LS1tech.com and search piston slap and then search oil consumption to get started on a few things to consider when buying a LS1.
Old Oct 6, 2005 | 12:30 AM
  #24
NewbieWar's Avatar
is this pretty common on these cars?
I remember my friend adding a bit of oil to his 02 SS, now that you mention it...
what is piston slap, also I've heard something about warping the disk brakes?
Old Oct 6, 2005 | 12:36 AM
  #25
StudyTime's Avatar
The LS1 had two different tanks. The '98s had smaller tanks than the 99+ cars.
Ben T.
Old Oct 6, 2005 | 12:38 AM
  #26
NewbieWar's Avatar
so does the 02 have 16.8 or 14?
Old Oct 6, 2005 | 06:23 AM
  #27
camaroz99b's Avatar
16.8
Old Oct 6, 2005 | 08:41 AM
  #28
NewbieWar's Avatar
is there a way to fix the oil consumption or the piston slap?
still not quite sure what piston slap is...
but if a rebuilt was done, what would solve these two issues?
Old Oct 7, 2005 | 12:14 AM
  #29
NewbieWar's Avatar
Got her...
Hope to see some of you around in this forum, never visited the ls1 forums...
Jun 6, 2015 08:27 AM
Jan 13, 2015 09:52 PM
ddr698
Jan 9, 2015 10:05 AM
25thTA
18
Jul 8, 2002 09:41 AM
