Brake Rotors
Old Mar 29, 2003 | 05:16 AM
GoFast908Z's Avatar
Member
Arrow Brake Rotors
I have several questions. So here goes:
1. What are some good, cheap, aftermarket rotors for the LS1?
2. Do slotted rotors (ie Powerslot, etc) really make that *snick snick* sound when coming to a stop?
3. What are the best pads (brand?) to use on Cross-drilled rotors?
On my last car (91' Honda CRX Si), i changed all 4 rotors (yes it had 4-wheel disc) to PowerStop Cross-drilled. I weighed the stock rotors and the total combined weight was about 80 lbs. The PowerStop rotors weighed only 65 lbs. The only problem with these brakes was that they had that ugly goldish color all the time. I HATE THAT.
4. Which aftermarket rotors (the cheap ones), are lighter than stock?
AND do NOT have that gold color?
Thanks for your help.
-Jeff
Old Mar 29, 2003 | 07:01 AM
1badLS1M6's Avatar
I just put Autozone rotors and pads on the front last week because they were warped BAD. And man what a difference. Its only been a week, but hopefully they wont warp. But i'm happy with them so far.
I dont know if they weigh more than stock, but they felt the same to me.
Chris
Old Mar 29, 2003 | 07:27 AM
GoFast908Z's Avatar
Member
I think i need to specify, I want Performance Rotors. Cheap? Yes. Autozone? No.
Cross-drilled and/or slotted
Old Mar 29, 2003 | 11:21 AM
1badLS1M6's Avatar
Sorry.
Old Mar 29, 2003 | 01:00 PM
chuck's Avatar
Eradispeeds are the only ones that will be lighter than stock, and they are NOT cheap.
The EBC's seem like the best deal in drilled/slotted rotors, and oif course AZ's are the best bargain of all.
Old Mar 29, 2003 | 02:25 PM
M3EATER's Avatar
I would typically not recommend a drilled only rotor for street use. They do not wear as well as slotted or drilled & slotted.
These PPC rotors are stress relieved and pre-seasoned before you get them. They are available plain or drilled & slotted.
These rotors work great for hi-po street and for road racing. They make an awesome dual-duty rotor.
I have found that a carbon based pad works the best for overall dual-duty and rotor life.
Gordon
www.provenperformanceconcepts.com
Old Mar 29, 2003 | 02:26 PM
GoFast908Z's Avatar
Member
EBC?
AZ?
Old Mar 29, 2003 | 04:11 PM
SUPERSPORTBOY2's Avatar
how much are autozone rotores and pads?
Old Mar 29, 2003 | 04:19 PM
1badLS1M6's Avatar
I replaced my front pads and rotors last weekend with autozone, and the rotors were $38.99 each, and pads were $39.99.
Chris
Old Mar 30, 2003 | 01:23 PM
is there a specific name for the rotors and pads or they just autozone brand pads and rotors. thanks
Old Mar 30, 2003 | 01:58 PM
ls1_bc's Avatar
Question
Autozone seem to be the the rotor of choice for value for money. We don't have Autozone in Canada does anybody know who makes their rotors or if they can be purchased under a different brand name?
Old Mar 30, 2003 | 07:29 PM
Camarocks's Avatar
Albany is the manufacturer that supplies Auto Zone with their regular brake rotors and pads.
Old Mar 30, 2003 | 07:50 PM
chuck's Avatar
Actually Aimco makes the rotor for an ls1 F-body that AutoZone sells.
Old Mar 31, 2003 | 09:07 AM
rncotton's Avatar
AutoZone rotors are great, but avoid the Albany brand pads. They squeal and have so much brake dust it makes your wheels nasty after only a day of driving. (I found out the hard way)
There's another set of pads that is only a few bucks more ... wishing I had gotten those instead.
But, I've always been happy with the AZ Rotors.
Cross-Drilled or Slotted rotors are just for looks.
Old Mar 31, 2003 | 07:11 PM
lastlaf's Avatar
Nobody has mentioned KVR yet. Probably not any lighter than stock but they are less prone to warping. There's a link in my sig.
