Borla Adjustable Catback
Old Jun 11, 2005 | 05:01 PM
UK_chevyV8's Avatar
A quick question for anyone with an adjustable Borla.
My new catback will arrive soon but which plate will give the best results, if I go for straight through (no plate) will there still be enough back pressure so that I don't reduce power?
Old Jun 11, 2005 | 05:08 PM
Kraest's Avatar
Retired
Re: Borla Adjustable Catback
You might move the torque up a little higher in the powerband, but you aren't going to ever reduce power like that.
Mike
Old Jun 12, 2005 | 03:06 AM
UK_chevyV8's Avatar
Thumbs up Re: Borla Adjustable Catback
Thanks, straight through it is then.
Old Jun 12, 2005 | 08:18 AM
Greed4Speed's Avatar
Needing backpressure for torque is a myth.
Old Jun 12, 2005 | 08:48 AM
pHEnomIC's Avatar
I have a cutout, I can definentally tell you there is more jump in the car throughout the powerband when i open it which is why i run it open all the time.
We have done straight pipes on quite a few friends cars and they all seem to like it and report more power.
Only thing you have to worry about is some engines require a little bit of backpressure to prevent valve float which wont bea problem for you.
Old Jun 12, 2005 | 08:51 AM
RE AND CHERYL's Avatar
An open exhaust will reduce low end torque. It's not a myth, it's a fact.
Old Jun 12, 2005 | 11:58 PM
Z28COnrad's Avatar
You dont "need back pressure for tourque". What you do need is an exhaust system designed to give you tourque WHERE/WHEN you want it. If you want the tourque off of idle for towing and such then get a smaller diamater exhaust. If you want tourque up high for high horsepower then get a larger diamater exhaust. As far as restriction goes I'm pretty sure it's a moot point. You would want the lowest restriction (bends, turns, kinks, baffles etc.) possible in either system.
Also, the only thing back pressure could possibly do to influence valve float is to make it worse, the valve has to close against the pressure of the exhaust system which is fighting to keep it open so less would be better in this instance. Then the valve has to open but I kinda doubt that back pressure is going to compress a valve spring instead of opening the valve. If you have valve float, get stiffer springs and lighter valvetrain equipment, dont change your exhaust. That's my take on it anyway, where did you hear that some engines need it?
Old Jun 13, 2005 | 10:14 AM
SSpdDmon's Avatar
My old '99 put down 346.4ft/lbs of torque at the wheels with the Borla wide open and no cats on the stock manifolds (talk about little to no back pressure). It did move up, but only a little to about 4,000 RPMs (which is only 400RPM's above the stock rating I believe). He's still going to have his cats (I'm assuming), which is where the back pressure lies in most aftermarket exhaust systems these days. Run it open and have fun!
http://memimage.cardomain.net/member...31_68_full.jpg
Old Jun 13, 2005 | 06:23 PM
mrr23's Avatar
just for kicks here's a little 'backpressure' test if you want to call it that. here's my borla w/small open plate vs bassani tru-duals test i did on my wife's 99 formula.
http://www.stealthram.com/familypics...avsbassani.jpg
didn't seem to lose anything going from a single 3" to a dual 2.5"
Old Jun 15, 2005 | 02:34 AM
slowpoke96z28's Avatar
might see a difference at below idle to about 2000, but after that it would be fine. i don't think you'd lose torque anywhere thru the RPM band though, with the open plate.
Old Jun 16, 2005 | 12:13 PM
Bayer-Z28's Avatar
Backpressure or not just tweeks the TQ curve. No BP and you will get High RPM TQ, some BP and you will get low RPM TQ. My low RPM TQ is incredible. I've heard the mid plate is the best. I think mine is WO. Sounds NICE at WOT w/ my catted LT's ..... It sounds COMPLETELY different from the outside. I had a friend get my drive by on video.....!!!OMG!!!
Old Jun 16, 2005 | 08:36 PM
99Blackt/a's Avatar
Your only shifting the curve
G-BODYT56
Jan 14, 2022 11:14 PM
93 RedBird
Nov 15, 2015 08:24 AM
WobblySausage
Oct 7, 2015 02:44 PM
football4life
Oct 4, 2015 07:48 AM
SEOJustin
Sep 24, 2015 04:39 PM
