Bolt-on stuff
It should not take more than 2 hours. HOWEVER, Note: SLP will include directions on installation. If you do not want to cut the stock exhaust off, and would rather remove it as a whole, DO NOT FOLLOW THEIR DIRECTIONS! You can't drop the rear axle enough to bring the exhaust over it unless you are on a lift. I tried it on jackstands and it ended up taking me around 5 hours because I had to remove the clamps, remove the panhard bar, shocks, and lower the suspension, and then I realized it wouldn't come out, so I had to bolt EVERYTHING back together and cut the exhaust off anyway. So much for keeping the stock parts....I destroyed the piping with a hack saw
cmsmith
Sep 14, 2015 09:09 PM
jackpawt883
Sep 10, 2015 08:53 PM
