Block protrusion question - picture attached
Old Nov 7, 2011 | 09:58 AM
65MalibuSS's Avatar
I'm planning on installing a GM Gen III / IV engine in my altered dragster but there are protrusions on the side of the block that I would have to cut off in order to fit the engine between the chassis rails.
What is the purpose of these protrusions?
Can I cut them off?
Thanks.
Old Nov 21, 2011 | 06:52 AM
AL SS590 M6's Avatar
Moderator
Re: Block protrusion question - picture attached
Back in the day I used to run the initial block machining line at the Oldmobile plant in Lansing. The raw block is loaded onto the line and the first machining process is to clamp it onto the cast in locating pads. Then a mill cuts the verticle and horizontal surfaces of the pads that you're pointing to. They become the first precision locating pads for the rest of the preliminary flat surface maching operations ie. pan rail, rough bank, then locating hole boring. After that they are useless. Go ahead and cut them off.
Noenav
Mar 1, 2019 07:38 AM
MadMav
Feb 6, 2015 11:02 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
Injuneer
Dec 15, 2014 09:36 AM
Jul 4, 2005 05:00 PM
