The Best Radiator Cleaner?
Old Dec 16, 2002 | 09:40 AM
therealmagyver's Avatar
Which one is it? My radiator seems to be clogged. Temp is at 240 idling with fans on or highway speeds. I really hope its not my water pump. I have 65000 miles and the radiator seems fine on the outside.
Old Dec 16, 2002 | 10:07 AM
6speedZ28's Avatar
Have you checked for a bad thermostat yet....seems more likely than a clogged radiator.
Old Dec 16, 2002 | 10:27 AM
My temp goes to 240 when I am idling and during highway speeds so that should eliminate the thermostat. I did take the thermostat out and it seems ok from what I can see. I can also compress the springs with not that much an effort so I am leaning to the radiator.
Old Dec 16, 2002 | 09:56 PM
I changed the thermostat and that did the job. Funny how the thermostat went bad outta nowhere. I mean in the morning it was fine and the car sat for a few hours then in the afternoon the problem started.
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
68camaroboltz
Oct 5, 2015 01:46 PM
Pwilson59
Sep 3, 2015 08:47 PM
