belt tensonor
Old May 28, 2004 | 08:47 PM
mook99TA's Avatar
belt tensonor
My belt tensonor is a bit loose and shakes a little was looked at it and can't find where to tighten it does anyone know how or a site that shows it....would that have anything to do with my problems starting the car? Still can't find whats causing the starting problem battery is fine starter is fine alternator is fine....it just seems to reset itself when I try starting it and when it does start its fine I am at a lose for words
Old May 28, 2004 | 11:16 PM
DARK AGE 53's Avatar
Sounds like you need a new tensinor, as for you car not starting what do you by it " resets itself "?
Al
Old May 29, 2004 | 06:15 PM
mook99TA's Avatar
seems like the pcm resets itself. The speedo and rpm needles jump up about half way and the trip resets. Runs fine when started but won't turn over when trying to start
Old May 29, 2004 | 07:06 PM
Reseting of the speedo and trip was a common problem on 99's, usally it was caused by a weak battery......if you can I would try a new battery. JMO
Old May 29, 2004 | 07:38 PM
http://web.archive.org/web/200111081...08-49-009.html
Old May 30, 2004 | 11:35 AM
mook99TA's Avatar
The trip and everything reseting is a problem but my main problem is the car has problems starting it might start one out of every ten tries. The battery isn't weak I tested that the other day and its puting out 12.5v. Could I possibly have a loose ground somewhere?
Old May 30, 2004 | 11:55 AM
Is that with the engine running, also have you checked what the volts are while cracking the engine over?
Old May 30, 2004 | 12:01 PM
RxNupe's Avatar
My '96 Z28 did the same thing. My battery even tested ok. I took my dad's battery out of his Tahoe and the car started right up with no problems.
Old May 30, 2004 | 12:38 PM
anasazi's Avatar
get the battery tested
a voltage reading doesn't tell the whole story ... amps is what turns the starter
Old May 30, 2004 | 04:17 PM
mook99TA's Avatar
I have a multimeter to check the amps the bat is putting out what is a good reading?
Old May 31, 2004 | 12:06 PM
pg318's Avatar
Don't even try to measure starter current with a multimeter, its probably 250+A. If the meter's got a fast max-min capture set it to volts and find the lowest value the terminal voltage falls to when you try to start the engine. I'm not sure what the PCMs are sensitive to on these, but it should be no less than around 8V at in 50-70degree weather. Slower capture (>10ms) will only show the mean cranking current dip, probably 10-11V.
If you haven't got those facilities, take the battery to an auto parts store, most have load testers that draw current through a big resistor to check the voltage fall.
95blkss
Sep 22, 2015 03:18 PM
rideordie
Sep 7, 2015 08:22 AM
WPHIG2
Aug 27, 2015 06:37 AM
john henry
Aug 14, 2015 08:33 AM
john henry
Classic Engine Tech
