Bad clutch diagnosis help
Old Jul 9, 2003 | 04:39 PM
LS1Nat's Avatar
The other day while I was accelerating to pull inot traffic, the clutch started stinking really bad. Ever since I bought the car, I've noticed that when I pull out slowly (or hard) the car shakes just slightly until I get moving. Could this be a sign that the clutch is bad or getting bad? The warranty is good for another year so I want to make sure to get it fixed before it expires. Can a bad clutch cause the car to shake slightly under these conditions?
Old Jul 9, 2003 | 06:17 PM
SSpdDmon's Avatar
It could be the flywheel has warped a little. If they make the flywheels the same way they make the rotors, I wouldn't be surprised. j/k Either way, it sounds like you need a new clutch/flywheel assembly. Time to call SPEC.
Old Jul 10, 2003 | 12:20 AM
fbird95's Avatar
Yeah a slipping clutch or a warped flywheel can cause what you described. If you smell burning clutch, its probably the clutch dying.
Old Jul 10, 2003 | 01:06 AM
Ferocity02's Avatar
Put the car into 5th or 6th gear around 40mph and floor it. If the revs pick up but the car does not, then you know you have a slipping clutch. Either way it sounds like a bad clutch.
Old Jul 11, 2003 | 10:20 AM
LS1Nat's Avatar
Thanks for the replies guys! I had a feeling that's what was wrong. Maybe this is what's making me feel that this car is so slow. If the clutch isn't engaging completely and there's slipping under heavy load, the car won't accelerate the way it should. Hopefully the new clutch can help wake this car up.
Briah.hood
Feb 17, 2015 02:10 PM
HectorM52
Jan 30, 2015 11:08 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
mattszm6
Dec 14, 2014 07:09 AM
IgorT.455/406
Jun 4, 2003 03:32 AM
