B&M shiftplus
has anyone tried this $40 unit, is it worth it?
It won't work on LS1 cars...otherwise it's a very cool unit...:)
Yes, it will work on our cars. But, you'll blow up your 4L60E.
In 98, the 4L60E was changed. The front pump went from steel to aluminum, and the Shift+ increases the line pressure quite a bit. Sooner or later, you'll blow the front pump because of the pressure demands. That's why it will work on earlier 4L60Es, because the steel pump is stronger and can handle the extra line pressure:) |
..a quote from their web site
part # 70380 For GM rear wheel drive and 4wd trans code MT1 or M30 (RPO code found on sticker in glove box) '93-'98 Suburban, Tahoe, Blazer (C/K, S/T), pickup (C&K) 1500, 2500, 3500, Impala, Camaro, Firebird & '94-'98 Corvette. |
So i guess that 93-98 note includes camaro, that sucks for you guys, but i've got a 3.8L, I only asked you guys because no one in the v6 section wanted to talk about it, but i guess the v6 doesn't matter, i'll have to research this more,
Yes, don't use it on a 98 4L60E.
Go check LS1.com or LS1Tech.com. You'll hear the same response. |
yeah, just found it on thunder racing, said it doesn't work on 1999+ f-bodies, that sucks.:(
| All times are GMT -5. The time now is 07:35 AM. |
