Anyone ever done the TB bypass and then CUT the unused tubes off the TB?
I was thinking about this for no real reason. Since I did the TB bypass, the two little tubes on the bottom front of the TB are useless and just get capped up (or left alone), why not just cut them off for kicks and to clean up the engine bay a tiny bit?
Anyone done this? Why not, right?
hadn't even considered it... with the airbox installed, you almost have to look for the tubes to even see them. I just capped mine with some black rubber caps and you can't see them anyway. I also figure I should leave them in case I sell the car and want to return it to 100% stock.
stockssn2o
May 25, 2015 08:54 AM
SMO Q
Feb 11, 2015 07:13 AM
