Any stock stall, bolt-on, 2.73 cars out there faster than mine
COMPLETE MOD LIST:
Whisper Lid
K&N Filter
LS1 Aluminum drive shaft (came with steel)
Dynomax bullet muffler dumped after Y-pipe
Ported MAF
Free ram air mod
Gutted cats
!Front sway bar
!rear seats
The car is a '01 Z28 with 2.73 gears on stock 235mm Eagle GA tires with the stock converter.
Best ET: 12.59
Best Trap: 111.23
Best 60FT: 1.88
The car is a freak for a 2.73 or hell for a 3.23 for that matter. Any faster 2.73's out there with similar mods??
2001 Pewter Camaro Z28 A4 with 2.73 gears: $187 in mods: 12.59 @ 109.7mph w/ 1.92 on stock Eagle Ga's
Best MPH: 110.4
2000 Pewter Camaro SS M6: Basic bolt-ons. Best ET: 13.26
Best MPH: 109
1999 Yamaha R1: Mig Carbon pipe, undertail kit.
Whisper Lid
K&N Filter
Ported MAF
Free ram air mod
Gutted cats
!Front sway bar
!rear seats
Best ET: 12.59
Best Trap: 111.23
Best 60FT: 1.88
Best MPH: 110.4
Best MPH: 109
Nice times man!
What did you car run stock?
I have a 2001 Z28, auto with 2.73s.
I ran 13.573 @ 103.18 in stock form.
I'm just starting to mod now, and haven't been back to the dragstrip yet.
www.CamaroHighway.com
Yahoo! Group - Chevy Camaro Z28
2001 Camaro Z28 A4 2.73 - Navy Blue Metallic - my 5th Camaro!
No mods ...YET!
Stock Dyno: 293HP/317TQ
Stock 1/4 Mile: 60ft: 2.054 1/8: 8.832 @ 82.56 1/4: 13.573 @ 103.18
Mods: SLP CAI, K&N Filter ...next up: Loudmouth!
No mods ...YET!
Nick you need to go get it dynoed and see how much hp it makes.
Having driven it I know the 2.73 benifits from two things. 1) The launch, the car is easy to tach up and launch. The 2.73 is not as prone to spin as a 3.23/3.42.
And secondly the gearing allows the car to be at the top of second at the traps. Thats the most optimum place to be at top rpm. Whare the 3.23 cars are just starting 3rd and 3.42 M6's are just hitting 4th. Both slightly off the sweet rpm range.
Lastly I think your car is light, being a hardtop with cloth interior. Then removing the front sway bar, rear seats, and exhaust from the collector back probably saved 50lbs.
And hey you can't beat the miledge and the punch from the freeway!
2002 Z28 white/neutral A4 3.23
13.33 @ 104.7 - 650 miles
286rwhp/311rwtq - 1300 miles
STOCK for now!
Gone but not forgotten,
1999 Silver SS 6M #3956
1997 Black Z28 A4 3.23
Ryan S.
STOCK for now!
Ryan S.
Do you have video or timeslip? I have a hard time believeing this...But if its true well then cool...I know someone who has a stock WS6 and ran 12.5 with just drag radials, but thats a 6spd car so the huge clutch drop was the factor..
With his 235/55 tires, he's only going to get 3-4 more mph per gear than my 245/50's due to his increased tire height.
http://www.f-body.org/gears/
If you call N20 a bolt on then yes...I gotcha
but if not then you will lay the smack down on me.
I do have some pretty impressive times though for my bolt ons.
I turned a 13.19 @ 105 with just K&N , Lid , and Dynomouth exhaust.This was infact in 39 degree weather also.
My other major feat was recorded in early september...
I sprayed the car at www.darlingtoninternationaldragway
and ran the times in the sig.
I actually turned a 1.69 60' on the stock GSCs.
Now that was incredible, because I ran door to door with a 11.80 mustang with Slicks.He couldnt believe I was on street tires, especially since he only cut a 1.67 60' on his stickies!
To this day Ive only managed mid 1.7 short times and seems to be getting worse due to tire wear.
My 2.73 gears are the main reason I dont need slicks when spraying.
Later bro and ...
Awesome times you got
Later bro and ...
The best I can turn is a 2.1
First off it helps to have the following...
Super Track prep that will pull your shoes off.
Experienced driver.
Automatics kick azz at the strip.
low stall TQ converter accompanied by 2.73 gears.
and almost 500 hp really helps
My Camaro has always impressed me on the stock radials.
I have many friends that run consistant low 1.7 short times on thier GSCs.
They have heads& cam packages also.
Later
Mike
Experienced driver.
Later
Mike
Jul 4, 2005 05:00 PM
