Any gain to polishing combustion chamber on heads?
Old Mar 3, 2004 | 02:22 PM
nikkev's Avatar
I think it's called the combustion chamber.It's the round indent where the flat part of the valves come into.I recently bought a set of heads that have a mild port/polish job to the intake/exhaust tunnels and they have brand new stock parts. Now, the combustion chambers have been smoothed out a little with no actual porting.I was wondering if they should be polished mirror-smooth or left alone?They are still a little bit rough right now.Also,the intake/exhaust tunnels are smooth,but should they be polished like mirror as well?Thanks guys...
Old Mar 3, 2004 | 04:32 PM
Demon SS's Avatar
yes it helps the burn pattern to polish the combustion chambers, just take your time and go slow until you get the hang of it. we polish the chambers on our Stage 2 heads
Old Mar 3, 2004 | 08:46 PM
nikkev's Avatar
Thanks for the reply and sorry about the newby question,but I am a bolt-on guy and heads are new to me.So you are saying that I should take some sand-paper and a polishing clothe and shine the chambers until they look like chrome (or close) correct?I just don't want to mess up the heads so I will NOT be using a grinding disc or anything.Thanks again...
Old Mar 3, 2004 | 10:31 PM
GoFast908Z's Avatar
Member
aren't you supposed to use a machinging tool to do that?
Old Mar 4, 2004 | 08:27 AM
nikkev's Avatar
Hehe, that's why I'm asking.The machine shop has done the porting/polishing of the tubes and the chambers.The tubes are smoothed out pretty good and the chambers are very rough compared to the tubes.The shop smoothed out most of the roughness from the cast in the chambers,but it is not polished up.
Old Mar 4, 2004 | 12:32 PM
Mikie's Avatar
I have a set of Scotts heads and cam on my LS1 and trust me guys. He knows porting and pollishing!
Nikkev,
Email Scott and he can help you more indepth on your questions.
Mike
Old Mar 4, 2004 | 08:08 PM
Demon SS's Avatar
We do all of our work by hand as it is my preferred method of doing cylinder heads. Just use some lite sand paper or an electric die grinder and some of these http://cgi.ebay.com/ws/eBayISAPI.dll...category=10323
take your time and use a soft touch and keep it even and smooth across the surface you'll be ok.
Old Mar 4, 2004 | 10:02 PM
nikkev's Avatar
Thanks a lot man! My heads look almost exactly like these (as far as the porting goes):
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2464798552
The only difference is that my chambers are still kind of "pebbly" so I am going to smooth them out by hand.I am hoping that if I do it by hand I won't take too much off and ruin the heads.Thanks for the replies!
Dmonty
Jun 2, 2015 11:19 PM
Roadie
Feb 16, 2015 10:34 AM
MadMav
Feb 6, 2015 11:02 PM
95chwagon
Jan 13, 2015 09:19 PM
