ANOTHER head and cam question
I am looking for the BEST h/c combo. The block is a 2000 ls1 with all lower internals stock. Will be mated to a th400, in a 3000lb vehicle. I want the BIGEST cam that can be used with the stock pistons without cutting. Emissions are not a problem, the motor will be in an offroad application. The rpm should be somewhere between 1500-6000. I want a heavy/rough, lots of lobe idle. Now I need heads to flow good with a suggested cam. I need to keep about 10.5:1 on the compression (pump gas).
Can someone please suggest the best h/c combo with all the specs listed. I will need to know int/exh, lift and lsa of the cam. I want to know the head cc, valve sizes, what springs and retainers.
Thank you, Joey
Thank you, Joey
Re: ANOTHER head and cam question
http://www.projecttransam.com/Projec...e&Search=False
http://www.projecttransam.com/Projec...n&Search=False
Read up. There's always information you can find to answer your questions. You just have to look for it.
oldschool
Feb 9, 2016 09:21 PM
