amount of psi?
amount of psi?
I;m in the market for a SC and i was wondering what the best amount of psi would be to run without blowing tranny and rear like some other guys....98 camaro ss...thanx Greg
Re: amount of psi?
On a stock motor, I wouldn't go over 7 1/2 lbs of intercooled boost. That's what ProChargers run at and they have a pretty sweet setup. If you want things to last a little longer, they have a 5 lb pulley you can get. I'm guessing the difference is ~130HP vs ~90HP at the crank. If it's a matter of parts not breaking long term, I'd run the 5 lb until track day...and then switch to the 7 lb. Just my 2cents.
Nayr
Mar 3, 2023 08:34 PM
RX Speed Works
Oct 1, 2015 10:19 PM
